TH30 Clean channel picking up local radio.
Hammerheart
Post by Hammerheart » Sun Oct 13, 2019 2:16 am
Clean channel picks up local radio. Dirty channel is fine.
First thoughts? Dodgy Valve? Any valve swaps I can try to pinpoint the issue?
Mr Mustard
Re: TH30 Clean channel picking up local radio.
Post by Mr Mustard » Sun Oct 13, 2019 2:21 pm
Pre-amp valve shield missing?
Mr. Mustard
Post by bclaire » Sun Oct 13, 2019 4:03 pm
Also, try a different cable. My first thought is though, bad preamp tube.
Hammerheart
Post by Hammerheart » Tue Oct 15, 2019 1:33 am
Ive tried cables/guitars/different power points. It does seem to be worse on one side of the house. im gonna try reseating the tubes tomorrow to see if its anything like a loose connection. I read on another forum this may be worth a try.
Hammerheart
Post by Hammerheart » Tue Oct 15, 2019 1:35 am
oh. it does it on both channels. its just way more prominent on the clean. I just noticed it sooner on the clean.
northernguitarguy
Post by northernguitarguy » Tue Oct 15, 2019 3:48 pm
Just curious....was it ever working? Did anything change, i.e. amp location, etc.?
Hammerheart
Post by Hammerheart » Tue Oct 15, 2019 6:53 pm
It was moved from UK to Canada. Voltage has been switched. Might just be my location. :/ obviously its just bugging me now as it didn't do it back in the uk.
Post by Les Paul Lover » Tue Oct 15, 2019 7:54 pm
Could you try another valve amp in the same location?
Hammerheart
Post by Hammerheart » Tue Oct 15, 2019 9:01 pm
all my other amps are ok (one is a rocker 15 combo)
Post by Les Paul Lover » Tue Oct 15, 2019 10:06 pm
Are sure the transformer rewiring has been done properly?
If all your other amps work correctly, and that one has been modified (I know, it a simple mod in theory), I would look there to start with - well, after trying a new ECC83 in each slot.
All the preamp valves have their shields, right?
Hammerheart
Post by Hammerheart » Tue Oct 15, 2019 10:15 pm
1-
2-
3-
1 - I did it. It operates fine apart from the radio issue so I THINK I did it correctly :P
2 - Next step maybe.
3 - yes
4 - a visit to the local tech in order.
Users browsing this forum: No registered users and 31 guests
