Rocker 30 gain/tube question
chachi
Post by chachi » Mon Jul 01, 2019 3:28 pm
Picked up a Rocker 30 head to compare to my AD30HTC head. I was expecting more gain out of Rocker. It has a little more than my AD30, but not a lot. I was hoping to run Rocker with no pedals. I run AD30 with OCD for boost/additional gain. With both amps set the same (including OCD), it's not a HUGE difference. The Rocker has more punch, it's a different flavor for sure. But without OCD I can't get the gain/saturation I was hoping for. Maybe this is just how the Rocker is, but I wonder if preamp tubes could be the reason?
This thread is on same topic and they mention a 12AT7 possibly being to blame:
viewtopic.php?t=50247
Mine has (left to right):
PM brand ECC83 / 12AT7 / ECC83
Output JJ EL34 (not EL34L)
Could I swap the 12AT7 around with one of the ECC83s to see if it makes a difference? I'd like to have a little hint that it will make a difference before ordering a fresh tube set.
northernguitarguy
Re: Rocker 30 gain/tube question
Post by northernguitarguy » Mon Jul 01, 2019 3:39 pm
Methinks that 12AT7 is there to buffer the FX loop. Changing it is not what you're after. I think you either need to push it over the top with an OD pedal. Trying out another brand of tube might bring out some subtle changes (this, after psychoacoustics wear off).
chachi
Post by chachi » Mon Jul 01, 2019 3:49 pm
No FX loop.
This thread has tube configuration, my 12AT7 is in V2 (ECC83 in V1 and V3):
viewtopic.php?f=2&t=39607
From the thread linked above:
"just put a new at7(ecc81) in the v2 slot. cool change, less gain, more tone."
I wonder if that's why I feel like I don't have enough gain?
Post by Jondog » Mon Jul 01, 2019 4:00 pm
The 12AT7 is not helping. Its not even the stock tube so whoever put it there was going for less gain. The Rocker has lots of gain, but it’s not a super high gain amp like a 5150 or even the Rockerverb. Ad30 has two gain stages, Rocker has three and the Rockerverb has 4. I’d put new 12AX7’s in which are rated high gain. You might look at a TH30 if you want more gain without spending a lot. Or get a Rockerverb.
Ronnie Robinson
Post by Ronnie Robinson » Mon Jul 01, 2019 4:08 pm
Could be changing to new ecc83s will help as long as you know it's a classic rock amp not a high gain one.
Orange AD30 HTC
Orange Rocker 15 terror
Orange Tiny Terror HW,
Previously Owned - Rocker 30
chachi
Post by chachi » Mon Jul 01, 2019 4:16 pm
It's weird b/c the preamp tubes are all matching (brand) PMs and the guy I got it from used it very little and as far as I know it was all stock. But, maybe not. From reading the other thread... if I put the 12AT7 in V3 it would change the overall sound of the amp... and in V1 and V2 it affects gain on Dirty channel. I guess swapping it around won't tell me too much - unless I swapped it with V1 b/c it affects the gain on Dirty channel less than V2? Meaning, I would get more gain with a ECC83 in V2 vs. 12AT7.
Is there that much difference in gain between a 12AT7 and ECC83 in this amp?
chachi
Post by chachi » Mon Jul 01, 2019 5:40 pm
It just occurred to me that I have my AD30HTC sitting right beside it. I'll pop a ECC83 out of it and try it in place of the 12AT7 in the Rocker and see what I get.
northernguitarguy
Post by northernguitarguy » Mon Jul 01, 2019 5:44 pm
No FX loop.
My bad. Yup, replace with an ECC83 and it should roar!
Ddjembe Mutombo
Post by Ddjembe Mutombo » Mon Jul 01, 2019 7:53 pm
I had both a R30 and AD30HTC for ten years. I retubed both of them from top to bottom. The R30 at 1 o'clock is basically the AD30HTC at 2 o'clock as far as gain. To be fair that is A LOT OF GAIN. After that it just gets loose. I've tracked plenty of beatdown riffs on the R30 and less is more. If that gain at 1 o'clock isn't enough, you are just using too much gain. If you are looking for a thicker gain structure, maybe you'd be happy with a more compressed sounding amp.
Monty
chachi
Post by chachi » Tue Jul 02, 2019 3:05 pm
Made the tube swap last night. There's definitely a difference. I can see how someone could like the 12AT7 in there, but I prefer the grit/gain as intended with ECC83. I would also probably prefer EL34L as well. Now I just need to figure out if I prefer this or the AD30HTC.
Boy_Narf
Post by Boy_Narf » Tue Jul 02, 2019 5:00 pm
I use a Rocker 30 for post rock/hardcore/progressive metal and it works fine without pedals. Are you playing single coils? Try a higher output pickup.
https://soundcloud.com/modestnews/float
Fast-forward to around 4:50 and you will hear a stock LPJ into a Rocker 30 combo (no pedals/plugins). R30C has a standard JJ retube kit.
PedalTrain2 | Zuma
www.scratchbuffalo.com
www.soundcloud.com/modestnews
Ronnie Robinson
Post by Ronnie Robinson » Tue Jul 02, 2019 5:03 pm
Yep that's a tough decision, both different yet both excellent.....
Orange AD30 HTC
Ronnie Robinson
Post by Ronnie Robinson » Tue Jul 02, 2019 5:07 pm
Yep that's a tough decision, I've said it before which is better an apple or a banana.
Orange AD30 HTC
Ddjembe Mutombo
Post by Ddjembe Mutombo » Tue Jul 02, 2019 5:16 pm
or a good clean boost to get that output up.
Monty
Post by Les Paul Lover » Wed Jul 03, 2019 9:25 pm
Yeap, the R30 dirt is pretty special. I bought mine super cheap intending to sell it on. But played it.... couldn't let it go!!!!
As for power valves, I've enjoyed both JJ and Tung Sol EL34 equally. However, I have some RFT EL34 in it now, and they leave the the m9dern EL34 trailing far behind. It's pretty transformative.....
Users browsing this forum: Baidu [Spider] and 10 guests
