ANYONE EXPERIENCED THIS PROBLEM BEFORE
ALMIGHTYxDEE
Post by ALMIGHTYxDEE » Fri May 24, 2019 4:25 pm
So I bought a brand new Crush 12w combo, and when I went to plug it up I have no power. It initially kicked my GFCI so I reset it and still nothing. Plugged it up to several outlets in my house and still no power. I tested the power cord and it was good, no blown fuses, plugged it up at friends house and it worked fine. Has anyone experienced this problem with outlets and if so how do you correct the problem?
Re: ANYONE EXPERIENCED THIS PROBLEM BEFORE
Post by bclaire » Fri May 24, 2019 8:34 pm
Yikes - never heard that one before. Did you try other outlets in your house?
Outlet testers that plug in are pretty cheap. It would be wise to invest the $10 and check to make sure your outlets are wired correctly.
Post by Jondog » Fri May 24, 2019 9:15 pm
Whats the voltage in your house
Users browsing this forum: No registered users and 195 guests
