Hello
can anyone suggest a way to record an orange amp (RV50) without having to use a mic? I would like to record in a live setting and looking for way to go straight into the board via an electronic means vs a mic which will have other stuff captured. Anyone have any suggestions, especially if you have recorded this way. I would like to know what gear you have used as the interface and how did you hook it up to the amp
thanks
tony
Recording an Orange Amp
Re: Recording an Orange Amp
I have used the Marshall SE-100 speaker emulator for recording a lot. They're hard to find, but it would give you exactly what you're looking for.
I've heard good things about the Hughes and Kettner Red Box
https://www.sweetwater.com/store/detail ... -simulator
Many options, depending on what quality of direct sound you’re looking for ie: Excellent quality cab impulse response simulation or basic analog circuitry to mimic the tonality if a cab or just straight sound from the amp, no cab simulation.
Also how much you’re willing to spend.
thanks. so if i understand correctly, this unit basically is simply tapping into the signal the amp head is sending to the cab? I guess it's 10k impedance doesn't disturb the signal into the cab....Have you ever used one of these...? anyone on this board who has?Ronnie Robinson wrote: ↑Sun Jan 06, 2019 7:53 amI've heard good things about the Hughes and Kettner Red Box
thanks
I use a Universal Audio OX. Top notch cab, mic, room, effects options. Doubles as an attenuator. SPDIF and analog outs.
I have a Mesa Cab Clone that I never really got along with until I saw a video on how to use EQ to get it to more closely match a Mic'd amp. Adding EQ is a big improvement and using the cab clone is great for recording ideas late at night when the family is sleeping but I still use a mic when I'm ready for serious recording. The Videos I've seen on the UAD Audio OX and One note torpedo sound fantastic but those units are a lot more expensive. I think whatever option you use you will have to use some EQ to get it to match a mic.
We tried one and I wasn't a fan of the results.11tonylevin wrote: ↑Sun Jan 06, 2019 3:02 pmthanks. so if i understand correctly, this unit basically is simply tapping into the signal the amp head is sending to the cab? I guess it's 10k impedance doesn't disturb the signal into the cab....Have you ever used one of these...? anyone on this board who has?Ronnie Robinson wrote: ↑Sun Jan 06, 2019 7:53 amI've heard good things about the Hughes and Kettner Red Box
thanks
Hardware options with analog cab sim are the cheapest, but the least convincing. HK Redbox, Mesa Cab Clone, etc.
A reactive load + digital cab IR will sound much much better. Choose your preferred reactive load, and you can get the IR from a plug in within your recording software, or a hardware unit that loads digital IRs.
Good reactive loads (provide a load for your amp and provide a line level signal which can be sent to a cab sim): Suhr Reactive load, Fryette Power Load, Two Notes Captor.
Good hardware cab sims that load digital IRs (you feed the reactive load’s line level signal into these): Mooer Radar, Two Notes Torpedo CAB.
Good digital recording IR plugin: Two Notes Wall of Sound.
The UA Ox provides a reactive load and cab sim in one box. It’s nice, but expensive.
If you only want to record and don’t need the digital signal for performance, I would use a reactive load and cab IR plugin on the computer. You COULD use a hardware IR loader, but it’s most expensive and you loose the ability to tweak the sound after it’s recorded.
If you want to use the digital signal for FOH, I would run something like the Suhr reactive load or Fryette Power load into a Mooer Radar or Torpedo CAB.
I’d stay away from analog hardware units like the Redbox, cab clone, etc. Unless you’re looking for the cheapest way to get a simulated speaker cab sound to FOH and not concerned with sound quality. If you’re going to a computer, digital IRs sound much much better than any analog unit.
This is assuming you don’t need attenuation, which opens up another set of things to think about.
I’ve mentioned it in other topics, but the expected Boss Tube Expander looks good. No price yet though.
Thanks to all of you for your inputs....Like everything else in this business, there are always many answers LOL
I did pick up a used Redbox 5.....it does the job for what I need. I am looking for something to capture the guitar amp during band practices so that we can listen back to the recordings and see where to make changes/adjustments. I was not planning on using it for recording or anything of high quality. Used to use a mic but we always had bleeding from vocals and drums...
BUT......I feel a bit uneasy about putting a $100 box between a $2000 head (RV50)and a $1000 cab (PPC212)! I kind of get that there is a "THRU" connection but something has to be tapping into the head's output signal to process it. So I wonder if this alters in any way the actual signal the cab sees. I have to assume that it's safe given that it is so popular, but maybe I'm just naive.
Users browsing this forum: No registered users and 265 guests
