Running incorrect Ohms question
TinMI
Post by TinMI » Thu Dec 20, 2018 6:59 pm
So I understand that running a 16 ohm head into an 8 ohm cab is a bad idea. But what about running a 16 ohm head on the 8 ohm option into a 16 ohm cab?
Ronnie Robinson
Re: Running incorrect Ohms question
Post by Ronnie Robinson » Thu Dec 20, 2018 9:33 pm
With a valve amp it's important to run the correct ohm out matched to the speaker, or risk causing the amp serious damage.
But based on your question, why not just use the 16ohm out on your amp to a 16 ohm speaker? If you have this already..........
Orange AD30 HTC
Orange Rocker 15 terror
Orange Tiny Terror HW,
Previously Owned - Rocker 30
TinMI
Post by TinMI » Fri Dec 21, 2018 1:33 am
It was more just a theoretical question. I noticed the inputs and thought, would that harm it? I couldn't find any results on any forums that asked that question. Thanks for your help. 16 ohms all the way!
Post by bclaire » Fri Dec 21, 2018 2:54 am
Depending on how you mismatch the impedance you could blow up your output transformer. Big money.
Sooner
Post by Sooner » Fri Dec 21, 2018 5:36 am
Here's a good discussion of mismatching impedance by one of the forum experts:
viewtopic.php?f=3&t=3346&p=26458&hilit= ... tch#p26458
Sooner
AD1512 Serial No. 001
Andy H.
Post by Andy H. » Wed Dec 26, 2018 2:11 am
Wow, old post! Still, the way valve amps work hasn't changed so much in the meantime... :lol:
