New Dark Terror Hum with no signal
chime13
Post by chime13 » Fri Dec 07, 2018 3:56 pm
Greetings All,
I just bought a floor model, Dark Terror in a music store in Peru and living in Ecuador I have no warranty.
Long story short:
After getting back home to Ecuador and having the amp plugged into my Laney LH212H (8ohm) and playing for a short bit, I noticed that a hum developed even when there is nothing plugged in and all knobs are fully counter-clockwise. It is much louder than the typical hiss I'd expect from an amp. Switching the amp tp 15w, the hum changes a little and ever so slightly, louder. I can raise the volume while playing to drown out the hum and it sounds fine except for the low-level hum.
Things I checked:
Line Selector correctly set to 110v (originally it was set to 220V)
Cables - all my cables have been cross-checked
AC Power - relatively clean and none of my other audio equipment exhibits electrical noise.
Reseated all the tubes (valves) I noticed that the 12AT7 was a different manufacturer and not JJ as all the other tubes.
Regardless, since tubes are not readily available in my area, I ordered a complete set of JJs thru Amazon and I should get them late January.
Could it be a faulty line filtering Capacitor or a bad 12AT7...
Any thoughts would greatly be appreciated.
Thank you,
George
Re: New Dark Terror Hum with no signal
Post by Les Paul Lover » Fri Dec 07, 2018 10:59 pm
It could be anything.....
Has your guitar humbuckers or single coils? (Though i assume that isn't the issue?)
Valve is very possibly the issue, but it could be any of them. Any of the 12AX7, 12AT7 or EL84.
I would recommend you swap them all, but 1 by 1, so you can isolate the noisy one and discard it. If it's one of the EL84, it's preferable that you keep a matched pair in.
chime13
Post by chime13 » Sat Dec 08, 2018 6:19 pm
Thanks for the response:
@Les Paul Lover :
It happens when there is nothing connected to the amp. No other guitar or amp I own hum.
@Les Paul Lover :
I figured as much...Hoping someone would suggest a filter cap....
Regardless, I have to wait until late January for my tubes to arrive.
Thank you
George
chime13
Post by chime13 » Fri Mar 01, 2019 6:52 pm
Just wanted to follow-up in case someone else experiences this issue.
Finally received the replacement JJ 12AT7 tube and it took care of the issue. No more hum.
I went ahead and replaced all the tubes with JJ's and the amp never sounder better, quieter and louder.
