OR15 No Sound
philip.roberts.4242
OR15 No Sound
Post by philip.roberts.4242 » Thu Nov 15, 2018 11:10 pm
Hey everyone, I am new to tube amp ownership and I love the OR15 I purchased used a few months back however after playing the other day I turned it off and when I went to turn it back on the next day I was getting no sound when I plugged the guitar in. I posted on a facebook forum and they suggested I try to replace the fuse next to the power plug (it was brownish). I replaced that fuse and am still not getting any sound out of the amp. When I look at the tubes they appear to be glowing but I feel like they may be dimmer than usual (not sure). I am getting no sound at all. I have checked the speaker cable as well as the guitar cable and both work fine on my other amp which I hate and replaced with this one. Please help!
Re: OR15 No Sound
Post by Les Paul Lover » Sun Nov 18, 2018 10:01 pm
Have you replaced the EL84 with a new set?
Gladmarr
Re: OR15 No Sound
Post by Gladmarr » Sun Nov 18, 2018 10:48 pm
Check the fuse again. If it is blown again, there is a problem with the amp that is making the fuse blow. Most likely a bad tube.
tulkas
Re: OR15 No Sound
Post by tulkas » Sun Jan 13, 2019 12:22 am
I have the same problem. Although, I have yet to change my fuse. Apparently I need to order one online. It’s a t250mA. My question is that the fuse looks fine, with an intact filament. Can a fuse be bad if it looks good? If the fuse isn’t the problem, what is?
Re: OR15 No Sound
Post by bclaire » Sun Jan 13, 2019 2:25 am
Fuses can look fine yet be blown. Always better to err on the side of just replacing them...
Re: OR15 No Sound
Post by Les Paul Lover » Sun Jan 13, 2019 10:28 pm
Yes, I've had a fuse looking fine, but when checked with a multimeter, it was dead.
Unless you can measure continuity with a multimeter, you cannot be sure.
