Hi,
Im considering of a buying some of head mentioned above. I know what are the technical differences between this two (i.e. tubes, transformers, lack of fx loop in terror) but I want to know your opinion about the tone differences. Anyone compared this heads? Which one do you prefer better?
I will plug in into orange 212 cab.
Rocker Terror 15 vs old Rocker 30 head
Re: Rocker Terror 15 vs old Rocker 30 head
I dont think you need be too concerned about the tone but be more concerned as to how your going to use it.
Mainly at home, or in studio or band practice need an effects loop? then the rocker 15. Limited clean head room.
If for gigs you need a loud beast of a dirty channel thats a bit punky and a clean channel thats good with pedals and sounds great when turned up ...but flat at lower volumes then the rocker30....also expect a very powerful mid eq knob with the other knobs making little difference and quiet to loud on the dirty channel by turning the volume knob about 1 mm!
Ive owned 4.
Ive owned 4.
I have the Rocker 15 Terror head and its brother the Brent Hinds. Both rock and can be gigged with especially thru a 412 cab or better full stack. It would depend on the venue; a modest pub or small club, no problem, someplace a bit larger and you'll need more volume then that location having its own PA system so you can mic it will be to your advantage. They are plenty loud for 15 Watt lunchbox sized amps but of course not arena rock stage gear yet then again with the right PA system in place you might be able to wing it!
Users browsing this forum: No registered users and 415 guests
