Rocker 32 Dirty Channel Volume Issue
I recently purchased an Orange Rocker 32 Tube amp and I almost exclusively use the clean channel with my board, however I've noticed that whenever I try to use the dirty channel there is almost no volume and I have to turn the volume all the up to get even a moderate amount of sound from it, which I feel is irregular considering the volumes it can reach on the clean channel, is this user error in some way or is my amp the issue?
Re: Rocker 32 Dirty Channel Volume Issue
I'd suspect V2 (dirty channel only) or possibly nut less likely V1 (shared between clean and dirty channel) is the issue.
Preamp valves such as the ECC83/ 12AX7 have 2 triodes, each providing 1 gain stage. V1 provides 1 gain stage to the clean channel, and 1 for the dirty channel. V2 has the 2 remaining gain stages for the dirty channel.
Whilst it's possible for V1 to have a single faulty triode, it's really rare.
i dunno i have my cleans at 9 oclock, dirty is always up around 1 oclock. And the volumes work well together. Mines a th30 but maybe you gotta turn up that volume on the dirty channel, these amps with el84s dont sound good without the volume up half way. ifs thats too loud put it into half power mode.
Users browsing this forum: No registered users and 84 guests
