i'm taking a signal from the send output of my JRT,the signal is variable using the Volume knob,can anyone tell me if it's a pre only signal,or is it pre/power,hope i'm explaining this well enough.
Thanks,Graham.
JRT Send Output ?
Re: JRT Send Output ?
The effects loop is after the pre-amp and before the power amp. All the controls, including volume are before the effects send.
Thanks PBA.
Be a good idea to pull the power valves out of the JRT.
Why would I need to do that Jondog?.
Unnecessary wear, depending how long you're planning to run it like this. Also if you don't have a cab hooked up, you could destroy the tubes and transformers.
Thanks,Jondog.Ok I understand,i'll explain what i'm doing with send output.
I'm running the JRT as normal with speaker connected(8 ohm),then i'm plugging the send into the Natural input in my R30C & using both amps.
Cheers,Graham.
Users browsing this forum: Google [Bot] and 208 guests
