Hi all,
New to forum. Seeking some advice on my effects board/chain with a Rockerverb 50 MkII and Micro Dark.
Recently switched from a Boss GT100 back to stomp boxes. I am a bit of an effects novice but they're important to get the ambient tones and drive required for the band's I'm playing in (Brit Rock/Shoegaze). Problem I'm finding is that I just keep getting a dead/very dull tone, especially if trying to use any sort of drive pedals through either Clean or Dirty channel (gain at 11-1 o'clock). The drives in particular just 'clash'?
My chain is as follows:
Front: Guitar>Hotone Skyline Tuner/Clean Boost>Hotone Wah/Expression>Electro Harmonix Germanium 4 Big Muff (OD and Dist)>Electro Harmonix The Silencer (Noise Silencer)
Effects Loop: Eventide Modfactor (multi-modulation)>Electro Harmonix #1 Echo>TC Electronics Mini HOF>TC Electronics Dittox2 Looper
The EHX Germanium is a 60s style OD/Dist - light OD and more of a fuzzy Dist as you would expect from a Big Muff pedal.
Any gems of wisdom? Thanks in anticipation!
Help with Pedal Board/Effects Chain
Re: Help with Pedal Board/Effects Chain
No experience with the Micro, but my RV50 MkII does not like many if any pedals into the front of the amp whatsoever, except the Bax Bangeetar I got to be VERY happy through the front on the Clean channel only. Dirt channel no way!! I also know I can't have the reverb past 7:30 even on clean.
In the loop I have a clean EQ/boost and chorus and reverb. They work perfectly there in every way.
I'd suggest you wait for others to reply but my experience is the RV50MkII is not a drive/distortion/fuzz pedal friendly amp.
Your mileage may vary!
RV50MKII Ltd., white +
2 stack PPC112's Orange
Micro Dark Terror w/ PPC112 Black
Bax Bangeetar white
"Addicted to the Orange + Les Paul sound"
Bax Bangeetar white
Unfortunately Lama is entirely right imo- and the RV also does n't clean up well from the guitar either. These were my main issues with my RV which led to me selling mine.
I'd experiment with a boost pedal through each channel like the xotic EP booster.
Users browsing this forum: No registered users and 294 guests
