Hi...I just bought a Blackstar HT-5, the 5 watt head, and I don't have a cab to try it out with at the moment. I do have a rocker 30 and was wondering if it would be safe for me to disconnect the speaker and run the blackstar through the rocker's speaker, to test it out, without harming the speaker.
Has anyone done this? Sorry if it's a dumb question, I'm kinda of a nube
Don't want to hurt my precious Orange
Thanks for ny help
Amp help
Re: Amp help
Match your ohms and you're good to go.
Just don't forget to plug it back into the Rocker when you're done.
Re: Amp help
Yes you can do this. Just disconnect the speaker jack from the R.30 combo and run it from the Blackstars 16 ohm output. Unfortunately the stock speaker cord is pretty short so you'll have to run them back to back. Be careful not to tug on the speaker connections. I soldered a slightly longer speaker cable in my own R30C to make this sort of thing easier.kat_shredda wrote:Hi...I just bought a Blackstar HT-5, the 5 watt head, and I don't have a cab to try it out with at the moment. I do have a rocker 30 and was wondering if it would be safe for me to disconnect the speaker and run the blackstar through the rocker's speaker, to test it out, without harming the speaker.
Thanks for ny help
Take care though and it'll be fine. Just remember never to power either amp up without having the speaker plugged into the correct impedance amp output.
Re: Amp help
Thanks so much for the quick help!
Users browsing this forum: No registered users and 226 guests
