Different types of amp design & construction
a.hun
Re: Different types of amp design & construction
Post by a.hun » Thu Oct 23, 2014 11:09 am
Is the hand wired TT still available?
Gut pics here:
http://forum.orangeamps.com/viewtopic.p ... ed#p593535" onclick="window.open(this.href);return false;
aNDyH. :wink:
Bensnake
Post by Bensnake » Thu Oct 23, 2014 12:58 pm
a.hun wrote:Is the hand wired TT still available?
Gut pics here:
Only second hand. I had my hands on one last year. Wish I've bought it...
Here's a Terror shoot out vid:
http://www.youtube.com/watch?v=4wNOK-JoXHc" onclick="window.open(this.href);return false;
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
S&m freddy
Post by S&m freddy » Thu Oct 23, 2014 5:27 pm
Here's an an ample of a hand wired amp with turret board construction.
Jim Root #4
Cornford RK100 and MK50
Cornford and Trace Elliot cabs
Gibson, Gordon Smith, Musicman, Fender guitars
onetracker
Post by onetracker » Fri Dec 19, 2014 1:58 pm
excellent post sir
a.hun wrote:PCB. The green bit with lots of white printing and copper lines is your printed circuit board.
In fact apart from the rare modern Custom Shop amps Oranges have ALWAYS been PCB construction. Though they used to chassis mount the valves instead of mounting them on the PCB itself as is done these days. However if the board itself is strong enough (yes) and is properly reinforced with spacers (yes) than unless there are any heat related problems (not so far) there shouldn't be any real big reliability issues. :D
Properly done PCB is just as reliable as any other build method, and is actually less likely to have noise issues due to random positioning of wiring, components etc. With PCB build everything is all laid out pretty much exactly the same from amp to amp. It is really just cheaply put together PCB electronics that give the technology a bad name. But a poorly built amp is poorly built even if that is all done PTP by hand! :wink:
PTP is in no way inherently more reliable than PCB. See this thread HERE comparing old Marshalls and Hiwatts, in particular posts #15 and #22.
During the later 70s Marshall went to PCB construction, but the reliability didn't drop at all at with that change. It was only years later (around 1990) when that happened, when they introduced a new range (JCM900) which were built to a price instead of to their own traditional high standards. The 70s Marshall amps (both pre PCB and PCB built) being discussed on that thread, alongside '70s Hiwatts, vintage Oranges and just a few others were (and if well maintained still are!) about as reliable as any amps ever built.
Remember though, there is more in many modern amps to go wrong than with those simpler older amps. Have a look at the inside of my OR120. Ignoring the (non original) doubled up capacitors on the PCB there is a lot less happening inside there than in your RV, right?
Your amp (like my Rocker 30) is put together to a pretty decent standard. Not the worlds best quality, but no huge issues either IMO. (Use of press on spade connectors being by far my biggest complaint!) Well above average run of the mill build quality at any rate.
But... with more complicated circuitry like the more complex modern amps there will inevitably be more potential for things to go wrong. Thats just the way it is and the reason why a lot of us believe simplest is usually best. Even so the vast majority of all problems with good quality modern valve amps are with the valves themselves. Keep a couple of spare valves and fuses handy and you and your amp will be fine!
Happy? :)
Greg1626
Post by Greg1626 » Tue Feb 17, 2015 6:02 am
Very interesting info here
Orange Rockerverb 50 , Orange TH30 , Orange Or15 , Orange PPC412 , 2000 Gibson Les Paul Classic , 2013 Gibson Les Paul Traditional Pro II with Floyd Rose , 2010 Gibson SG Standard , 2009 Washburn N4 , 90s ESP Sunburst Tiger , 90s ESP Skull and snakes
lunchbox
Orange Hero
Post by lunchbox » Mon Feb 01, 2016 7:02 pm
Solid State awesomeness: CR120
Post by bclaire » Mon Feb 01, 2016 11:01 pm
We now can add the total hand-wired Shiny Terror/ 10th Anniversary Tiny Terror to the list, which distinguishes itself from the previous hand-wired TT by being hand-wired without a turret board.
jontheid
Orange Expert
Post by jontheid » Mon Feb 01, 2016 11:10 pm
But I thought the original hard-wired TT didn't use a turret board either?
a.hun
Post by a.hun » Mon Feb 01, 2016 11:27 pm
jontheid wrote:But I thought the original hard-wired TT didn't use a turret board either?
Indeed! :lol:
With the new one you are paying for 'shiny' - shiny costs! :wink:
aNDyH. :wink:
Dino9
Post by Dino9 » Thu Sep 07, 2017 2:22 pm
Guys I am not an expert and a complete noob here just want to know your opinion on this amp manufacturer https://www.icrfq.com/brand/563 , would be very grateful for a review!
rutuja
Post by rutuja » Mon Mar 04, 2019 9:03 am
There is additionally another kind of development technique: PCB turret board. This is a blend of PCB follows turrets. This permits simple substitution of parts while holding the superb mechanical strength of PCBs. This was concocted and is only utilized by Matamp, who thought of the thought in the wake of fixing numerous Hiwatts taking note of the main issues were the wires connecting the turrets severing.
Post by Jondog » Mon Mar 04, 2019 5:55 pm
Friedman uses this too
Post by bclaire » Mon Mar 04, 2019 9:30 pm
I get nervous when old posts are resurrected by a first timer...
