El34 vs 6ca7 vs kt77
Also any wow moments for different brand 12ax7 vs jj’s. I currently have Mullard el34 which are great. I’m just wanting thoughts because I want to experiment.
Tubes rocker 30
Re: Tubes rocker 30
Wasn’t a fan if the KT77’s in my Rocker. Just didn’t seem to feel as harmonically rich as EL34 or 6CA7. 6CA7’s are great if you want to add some bottom end. Running EL34’s at the moment. Lots of punch.
Re: Tubes rocker 30
Yeh I am really pleased with the Mullard el34s. Tried el34l jj’s once. Didn’t like them. I tried 6ca7s. They were decent but the Mullard 34s smoked them. I read sometimes that tung sol 12ax7s are best Might try.
Re: Tubes rocker 30
EL34s for sure.
Which type is completely subjective ... I did try tungsol preamp amp tubes in the past and liked them a lot ...more recently tried them again and preferred JJs !
Re: Tubes rocker 30
I have a Tungsram ECC83 in V1, RFT ECC83 in V2 and V3.
The Tungsram really enhanced the sparkle on the natural channel.
The RFT bring up the rock in spade. In V3 (PI) it didn't make any difference which ever valve was there.
For the power valves, I have tried JJ and Tung Sol EL34, both pretty nice.
However I have some RFT EL34 in it now and that's a game changer. Pricey though.
Re: Tubes rocker 30
Tungsram helping the natural channel out ayyy. That’s kinda what I’m looking for. It doesn’t have any bad adverse effect harming the dirty channel in any way does it ?Les Paul Lover wrote: ↑Sat Aug 10, 2019 9:31 amI have a Tungsram ECC83 in V1, RFT ECC83 in V2 and V3.
Re: Tubes rocker 30
kpunk56 wrote: ↑Sat Aug 10, 2019 6:22 pmTungsram helping the natural channel out ayyy. That’s kinda what I’m looking for. It doesn’t have any bad adverse effect harming the dirty channel in any way does it ?Les Paul Lover wrote: ↑Sat Aug 10, 2019 9:31 amI have a Tungsram ECC83 in V1, RFT ECC83 in V2 and V3.
The Tungsram ECC83 is a really beautiful valve, it has a fuller overall sound, with more low end, mids, and more treble, and is more musical than comparable modern ECC83 to my ears.
It breaks up very smoothly too - a bit too smoothly for my taste in the R30 dirty channel, however, V1 is shared between natural and dirty channel.
You might like it though.
However, RFT ECC83 break up pretty hard, and have a tight sound too - and putting that in V2 really made the dirty channel raunchier than it was before.
It's pretty personal and this are my own observations.
I would add that whilst I could make the difference, I don't believe your band mates would notice, much less so the average punter going to a gig.....
That said.... I'm very very happy with the result achieved.
Re: Tubes rocker 30
Yeh I get it. When everything is going there’s no telling the difference in little details. But it’s kinda all about feel to the player. I was checking the prices of the tungsram and rft stuff and they’re quite pricey. I’ll have to give thought to if it’s worth it. I’m barely even playing out anymore. I’m just addicted to the r30. And you go through stages of wondering if things could be better.
Re: Tubes rocker 30
kpunk56 wrote: ↑Sat Aug 10, 2019 8:47 pmYeh I get it. When everything is going there’s no telling the difference in little details. But it’s kinda all about feel to the player. I was checking the prices of the tungsram and rft stuff and they’re quite pricey. I’ll have to give thought to if it’s worth it. I’m barely even playing out anymore. I’m just addicted to the r30. And you go through stages of wondering if things could be better.
I'll PM you re: some reasonnable Tungsram.
Re: Tubes rocker 30
Les Paul Lover wrote: ↑Sat Aug 10, 2019 10:00 pmkpunk56 wrote: ↑Sat Aug 10, 2019 8:47 pmYeh I get it. When everything is going there’s no telling the difference in little details. But it’s kinda all about feel to the player. I was checking the prices of the tungsram and rft stuff and they’re quite pricey. I’ll have to give thought to if it’s worth it. I’m barely even playing out anymore. I’m just addicted to the r30. And you go through stages of wondering if things could be better.
Sweet
Re: Tubes rocker 30
I like El34s. Smooth sound, bright mids and upper-mids, good note separation. Perfect for my riffs in the vein of AC/DC
Re: Tubes rocker 30
Get a hotter set that's about 10ma apart in bias at idle. They have to be hot to sound right, I'm talking over 24 watts idle. Did you measure the ones you tried? I'll bet they were cold. I had a cold set in a R30, and when I put a hot set in, holy hell! Was heaven!
The JJ "KT77" is the finest modern EL34 type valve available, bar none. Check out Gjika amps on YouTube.
Users browsing this forum: Google [Bot] and 248 guests
