Rocker 30 Combo with external cab?
Contemplating a beat-but-functional Rocker 30 combo, just wondering if it will work with my 16-ohm ppc112 as an extension cabinet. I would like to run both the internal speaker and the ppc112 at the same time to make a big noise. Can't seem to find a manual for the combo anywhere but this will work somehow, won't it?
Re: Rocker 30 Combo with external cab?
never mind. search solved this question.
Glad you found the answer already.
Simply plug both 16ohm speakers into the 8ohms taps.
It should sound great. Just so you take that into account, if the combo has been well used, i would plan for some new EL34 too.
The amp is cathode biased, so it's simple swap you can do yourself.
Users browsing this forum: No registered users and 276 guests
