I want an Ad30
I want an Ad30
It’s been along time ago since I played through an Ad30. Like over 10 years. But I remember it being pleasing. I have a rocker 30 currently. What I don’t understand though is I read things saying that they are super low gain. I didn’t remember them being like that. I seem to remember that they had sufficient amount. Why do I keep reading and hearing this ??? Anyway I’m on a quest to find one locally to compare I don’t want to get rid of my rocker. I just want both ;-/ Share thoughts please. Is there that much less gain than r30? Share thoughts please. Jimmy page tone with ad30 is amazing.
Re: I want an Ad30
Are you talking about the ad30 twin channel?
They are not super low gain so no idea where you've heard that, it's got about the same amount of gain as the R30 .... , but due to its quality the knobs can be used to set it up to give it quite a lot of clean headroom ie with volume on max use gain as the volume control and channel one really sounds good set clean this way, you can certainly do the same with the R30.
Re: I want an Ad30
See that’s what I thought. I don’t recall it being a lot less in the gain area than the r30. It’s just been so long since I played through one but when I read reviews it almost seems like they act like you don’t have any unless the amp is cranked wide open. I hope I can find one to just mess with one for a little bit.Ronnie Robinson wrote: ↑Mon Aug 19, 2019 4:21 amAre you talking about the ad30 twin channel?
I kinda would like to get a th30 also. Ad30 first for sure. I want a collection.
Re: I want an Ad30
I think I’d go for the twin channel. But I wouldn’t be apposed to a single if I came across one.Ronnie Robinson wrote: ↑Mon Aug 19, 2019 4:21 amAre you talking about the ad30 twin channel?
Re: I want an Ad30
The AD30 is just brilliant at low gain settings. The channel 1 is amazing at those edge of break tones, and the gain increase is very gradual, making it super easy to add the gain you need.
Whereas the R30 is pretty abrupt.... at noon on the Dirrty channel it still almost clean, at 1 o'clock it's pretty thick and filthy....
Both great amps.
Both great amps.
Re: I want an Ad30
Les Paul Lover wrote: ↑Mon Aug 19, 2019 2:41 pmThe AD30 is just brilliant at low gain settings. The channel 1 is amazing at those edge of break tones, and the gain increase is very gradual, making it super easy to add the gain you need.
Both great amps.
As someone with an Ad30 and an r30. What do you think you’d pick if you had to have only one ? I see you have an ad5 and 15 also. I kinda want one of each of those as well.
Re: I want an Ad30
Well duh. I’m sorry I read wrong. I guess you got rid of the rocker —- do you prefer the ad?
Re: I want an Ad30
I only played an AD30TC once. Wasn't a huge fan of how the channels differed. If I ever saw a single channel head (did they even make one???) I would snatch it up in a hurry!
The AD30 does sound glorious on edge of breakup. The R30, does not do that sound very well. R30 is all about roaring gain. Versatility would lead me to the AD30 + boost if you need more gain.
Re: I want an Ad30
I didn't keep the AD30tc because it was a combo.... (massively heavy) and I have an AD15, same as the channel 1 on the AD30tc.
The AD30tc did sound bigger and better than my AD15, but I already had my RV50 for bigger watt needs, and the AD15 combo was more practical and still sounds phenomenal, so I kept that one. The AD15 is a brilliant grab and go practice amp.
I also have an AD5 (No rectifier, sounds quite different. The AD5 reminds me more of the R30.....).
So I'm very lucky.... I have the AD5, AD15, R30 and RV50. And I love them all, all quite different really.
Make no mistakes, the AD30tc is a modern classic. Sounds incredible at jazz, blues, rock, indie..... great amp.
Re: I want an Ad30
I read wrong too..... didn't see your previous reply in my quoted message!!!!!
If I had to have one only of the R30 or AD30.....
I suppose the AD30 makes more sense. Sounds great, can do any rock tone you want. More polyvalent, and the AD30 has some of the best cleans I've ever heard.
But, god, the R30 dirty channel...... that's something special.
Essentially, I'm really glad I don't have to make the choice!!!!
Re: I want an Ad30
Several years ago on two separate occasions 2005 and then again my band recorded in two different studios. The first of which had several amp options. The AD30, a boogie studio 22, tweed bassman, a sovtek mig 60 and a Marshall jmp. I was smitten with the Ad30. Two years later a different studio had one and I loved it. Fast forward to 2014 when I got my R30. I didn’t feel like it was a ton different. But maybe more in your face and less spanky. Which I guess as a preference I would like more spongy at low volumes. But live I think I’d prefer more raw like the r30. I have gigged several times with the r30 and it has delivered and never let me down. I do go through phases where I get absolutely obsessed with orange amps. So recently I have been wanting one just because I want one. Do I need it ? Not really. But why not. Now the quest for one might take awhile because well I don’t play out nearly as often now and when I do the r30 is there. I have a wife I have to justify to and a child lol. But anyhow if I get my hands on one and fall in love I will make it happen. Or if I can find a deal hard to pass up .. also I’d probably get the tc or combo. But the single channels look cool. Before I even recorded with an orange I saw a band called Broken Teeth and their guitar players tone was soooooo good he had an Ad30 single and 2x12. Kinda was the first spark into the world of orange. So if I come across a single for a good deal I guess I could deal.************oh and btw the second studio from 2007 had a rv50 and I hated it. I felt like it was the most stiff and brittle amp. It didn’t seem to have complex harmonic texture like the ad30 did or the r30. Absolutely hated it
Re: I want an Ad30
I think the amp is thought of as low gain in comparison to other modern amps. It certainly isn’t something like a deluxe reverb where you have to push the volume to get any gain but I feel like it needs more volume to get a good gain tone compared to stuff like my RV or TH30.
I remember first trying out the AD30tc combo at a local guitar store and hating it. It felt so bland and lacked any real character. Then I grew up and realized it’s intentions and uses... it’s funny because the AD30 I tried years earlier never sold at the store so when it went out of business, I snagged it for what felt like theft. I love the amp.
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
Re: I want an Ad30
Awesome thanks for sharing.
Re: I want an Ad30
Yep , I can see why they may come across as bland in a shop setting ....they need volume and the valves working hard ..... then they sound great.afjungemann wrote: ↑Fri Aug 23, 2019 1:39 pmI think the amp is thought of as low gain in comparison to other modern amps. It certainly isn’t something like a deluxe reverb where you have to push the volume to get any gain but I feel like it needs more volume to get a good gain tone compared to stuff like my RV or TH30.
Re: I want an Ad30
It's funny, l remember trying out both the R30 and AD30 in reasonably high turn over UK shops. I didn't like them then, and they didn't sound like how I know they can. I reckon I played them through new display cabs, with unbroken V30 speakers. Just really harsh and stiff.afjungemann wrote: ↑Fri Aug 23, 2019 1:39 pmI think the amp is thought of as low gain in comparison to other modern amps. It certainly isn’t something like a deluxe reverb where you have to push the volume to get any gain but I feel like it needs more volume to get a good gain tone compared to stuff like my RV or TH30.
Not anything like the AD30tc combo I had, which was lovely, or my R30 through my well broken in PPC212.
Users browsing this forum: No registered users and 375 guests
