I use a Dual Terror with one or two Orange PPC112 speaker cabs. The question is - how do I connect the two speakers to the Micro Terror head that has only one output socket? Can I connect them in series that is from the head to one cab and then from that cab to the second cab?
I was thinking about taking the Micro head to gigs and if the Dual failed use the Micro as a back up to drive both speakers. It already sounds big through one 12inch speaker.
Micro Terror and cabs
Re: Micro Terror and cabs
Daisy chain the cabs and run out of the single speaker output. That will show an 8 ohm load, which is the lowest a MT can handle.
Thanks that's really helpful. Will try it out.
Sidepoint: Orange's online manual for the Micro says 4 ohms is still ok. At full output the amp may get warm enough to activate the thermal cutoff -- first stuttering on/off/on, then shut off entirely until it cools down. But no damage.
The early ones were labeled 4 ohm minimum. They didn't redesign the amp in response to some complaints about the thermal cutoff -- they just changed the label to say 8 ohms minimum.
Thanks that's interesting
Users browsing this forum: No registered users and 215 guests
