MT20 + Load Box
ili4
MT20 + Load Box
Post by ili4 » Wed Jan 23, 2019 4:20 pm
Hi guys!
I want to connect my Micro Terror to AMT Pangaea CP-100 (IR player-cabinet emulator) using Speaker Output (on the back of the amp). Is it necessary in this case to use the Load Box (I have AMT Power Eater PE-15) that connects to the THRU input (on the Pangaea)? It is believed that MT20 scheme does not allow this.
Re: MT20 + Load Box
Post by bclaire » Wed Jan 23, 2019 9:19 pm
Not sure. In looking at a picture of the PE-15 it looks like it wants a cab connected.
Bolotskih
Re: MT20 + Load Box
Post by Bolotskih » Sun Jun 30, 2019 6:54 am
Там транзисторный оконечник, он не сгорит без нагрузки. Хотя в манулае на орандж требуют подключать кабинет, нужно прислушаться. Используй PE15 в качестве нагрузки, будет круто. Подключай спикерный кабель от усилителя ко входу amp 8 ohm, в пангею с выхода DI.
Use PE15 as a load, connect it to the amp to AMP 8 OHM socket, then from the DI otput to pangaea.
Users browsing this forum: No registered users and 0 guests
