Cr60c vs micro dark
Cr60c vs micro dark
I made an impulse decision on the cr60c in store today, completely forgetting about the videos I've seen on the micro dark. My normal play style is sludge/stoner metal. Should I stick with the cr60, or spend the same amount on a cab and the micro dark?
Re: Cr60c vs micro dark
I'm afraid the only answer is in your ears. Noone here will say what's better and worse, however my recommendation would be micro dark + cab, simply because you can always upgrade your amp and use it with cab. Combo is kind of limiting, but if you like its tones, then rock on!
Users browsing this forum: Google [Bot] and 339 guests
