Basically I'm looking for an amp that can do the edge of breakup and dirty side of a OR50 in one amp. Is there anything like that out there?
2 channel OR50, does it exists?
Re: 2 channel OR50, does it exists?
OR50’s take pedals well.
Set it for edge of break up, put your favorite pedal in front.......and there you are.
There was the OR100, with clean channel and dirty channel.
It can be switched to 50w.... and I guess you could set the clean channel to pretty loud with some edge of break up.... and the dirty louder and filthier.
Other than that, and transparent OD is what you need or..... the Mad Professor Evolution Underdrive. That last one let's clean up your amp..... set your amp for filth, and set the Underdrive to bring it back to edge if break up.
If you're looking for an amp with two similar channels that are independent, you need to try the AD30TC.
AD30TC is going to give you the ability to do that. The RV MKIII has an attenuator so you could get your clean channel at the edge of breakup at about any volume level and then you have your dirty channel for the full on gain.
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
As stated above... The ad30htc will get you close, not exactly the same but close.
Users browsing this forum: Google [Bot] and 428 guests
