Orange's Shape Control
Post by adkguy07 » Tue Jan 01, 2019 1:46 am
I'm just wondering how those Orange amp owners who have a TH30, Dark Terror, or any other Orange with a shape control do get along with it. I've had my Dark Terror for over a year now and although I would not say the shape control is the easiest to use, I have to say that I get along with it quite well.
I learned what it does and does not do by experimenting with my two Les Pauls. There is a fine degree of tuning within its range and I only realized that after the V30 in my cab became fully broken in. Where I prefer a bright amp tone really means I use the range on the shape knob
between 2 and 2:30 o'clock.
Was the shape control a deal breaker for you when you tried or bought an Orange amp with it as theonly e.q.? Or, did you find that you eventually embraced the simplicity of it?
Re: Orange's Shape Control
Post by Jondog » Tue Jan 01, 2019 2:49 am
I think its neat, but not a big fan of it.
Sootio
Post by Sootio » Tue Jan 01, 2019 11:14 am
I have zero problems getting exactly what I want out of it, but it is quite different and I can see why some folks need a more traditional EQ. Once you get a feel of it, you can do some rapid and radical EQ changes on the fly.
mici88
Post by mici88 » Tue Jan 01, 2019 11:24 am
I used to think it's great and useful feature, but after a year of having TH30 I changed my mind. It was OK for one setting (somewhere between 10:00 and 12:00), anything below of above was terrible sound. So, now I can say it is great if you are set and forget guy, but if you like to tweek then sooner or later you'll find it limiting.
Now I'm happy with traditional EQ on my RV50.
stargazer747
Post by stargazer747 » Tue Jan 01, 2019 2:05 pm
I have a Dark Terror and have found my sweet spot on it to be just between 1 & 2 o'clock (which, incidentally, is the same spot on my Micro Dark Terror). I do find it to be extremely sensitive and the very slight movement will alter your tone just that little bit more and that's what I feel is fundamentally the heart of frustrations other players may have with it. This knob essentially is the treble, middle, and bass all in one, its more likely you can alter a tone with the slightest change where as with the 3-band EQ the tone will not be altered as much when adjusting them independently.
Post by adkguy07 » Tue Jan 01, 2019 3:01 pm
I hear ya! Glad someone else has discovered what is not so obvious to many. I also found that the shape control becomes more sensitive when I turn my amp volume up a touch more....including gain. From the get go, I delved into the myriad of gain tones from my own Dark Terror, but this past week I decided to trim the gain and try playing it clean.....as clean as I can get it. As a few reviewers have written, there is a definite clean side to this amp and I for one am glad the Ade didn't forget those of us who like playing clean on occasion.
Sootio
Post by Sootio » Tue Jan 01, 2019 3:04 pm
The sensitivity is part of what I like. I would be complaining if it wasn't sensitive. I haven't found going between say 10:00 and 11:00 is going to ruin my day, but there is a difference. I think I just really like the one knob simplicity.
Post by Jondog » Tue Jan 01, 2019 3:18 pm
Where it didn’t work for me was I couldn’t dial out something I didn’t like. I could find a good sound no problem, but on my Rocker for instance I like everything maxed in the EQ, and dial out what I don’t want, usually treble or bass depending on the guitar. I don’t like scooped sounds, so theres really only one spot I liked the shape control set and that was all I had to work with. All passive eq’s sacrifice something when you adjust one thing, but the shape sacrifices more when adjusted. It’s a nice compact eq control though.
stargazer747
Post by stargazer747 » Tue Jan 01, 2019 4:07 pm
Yeah, forgot to mention that a one knob solution to a 3-band EQ simplifies your spending endless time tweaking and not actually playing. Orange has often made it their mission statement that on their amps, in keeping a true signal to ultimate tone would be better achieved with the least amount of interactions in between.
Post by Jondog » Tue Jan 01, 2019 4:41 pm
The problem with your statement is that the shape control is a traditional three band eq configured into one knob, a dual gang pot for treble and bass. Fixed value resistor for mids instead of a pot. Same number of components interacting with the tone. Just less control. I think it’s a neat design, clever really, but not my favorite. I don’t spend a lot of time tweaking. Pretty much set and forget. I know one of my guitars likes some bass rolled off, but everything else left alone.
Sootio
Post by Sootio » Tue Jan 01, 2019 9:29 pm
I think we all kind of settle on one place that sounds good to us on any amp, but I use the whole left side of the shape control for different things, and I'm pretty sure I can approximate what you've described. It's not for everyone, though. A good old 3 knob eq is is a known entity, and just feels comfortable.
Post by Jondog » Wed Jan 02, 2019 12:32 am
My easy answer is if it works for you, then thats all that matters. If we all liked the Fender Bassman the way it was, thats all we’d ever have.
stargazer747
Post by stargazer747 » Wed Jan 02, 2019 1:16 am
Of course it all comes down to what type of pickups on the guitar as well as FX pedals or lack of them are all contributing factors that with the one knob tone/shape control you'll have to find the sweet spot where it all balances out but for you and your ears alone will you determine if it will work.
Post by adkguy07 » Wed Jan 02, 2019 1:57 am
I was going to mention the same re: pickups. Once I swap to my 2nd. Les Paul with different pickups, it usually means the tweaking of the shape control in concert with the gain and volume controls, begins anew. Once I establish the sweet spot among all three, I usually realize I can do
it quicker with the shape control as opposed to a 3-knob e.q. section.
afjungemann
Post by afjungemann » Thu Jan 03, 2019 11:44 am
I have a TH30 and for the most part appreciate the charm of the shape knob but the 3 band is where it’s at for me. The RV and AD eq is very tolerant to adjustments unlike say a Mesa so turning any knob too far doesn’t necessarily ruin the tone. I have found I like to dial in a lot of mids (usually dimed) and moderate highs (around 3 o clock) and then rolling out quite a bit of bass (somewhere between 9-11 o clock) which gives me a really nice punchy tone with a les Paul. That eq setting doesn’t really exist on the shape knob.
In my world, the shape knob is not any faster to adjust than an orange 3 band and it is only more limiting. The TH30C is my grab and go jam amp, otherwise I would sell it.
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
