Rverb 50 vs Tverb 50 - I know, a perennial question
Hello
I know this is a recurring question, but I need to figure this out. I own a Thunderverb 50 head driving a PPC212 cab. I like it a lot. Having said that I have noticed that I sometimes get lost in the mix. Tried different settings on gain, tone etc.
I have been curious about the sound difference in the Rockerverb 50. I can't find a demo in stores where I live, so the only choice is buy it to compare. That's an expensive experiment. Done lots of reading on the differences. More importantly tried to find youtube clips to hear the differences. I am 58 yrs old and will admit I have some hearing loss, highs especially. Notwithstanding that from what I have observed in listening to comparisons is that the R50 has a more "airy" brighter crunch whereas the TV50 seems more low end and dare I use the term "muffled", generally a darker sound. From what I hear, it sounds as if an RV50 could cut better in a mix because it is crisper. I don't know how else to explain it. Is that what is modern compared to vintage compared to classic compared to whatever? So two things: a) does my description make sense to anyone reading this and does it reflect the general tonal differences and b) for anyone who is intimate with both models, any words you can use that helps separate the two? I am itching to buy the Rockerverb but just worried they are too close in sound to make it worth the large investment
Many thanks
tony
Many thanks
tony
Re: Rverb 50 vs Tverb 50 - I know, a perennial question
Your description makes sense. It’s designed to have more low end. I think its a great amp, but the Rockerverb is maybe more versatile.
The RV50 under heavy gain compresses quite lot on the dirty channel, which can make impact dynamics hit and miss.
The RV50 is more modern sounding, and still has a lot of low end. It's thick, warm and that's the main place it takes in band setting. If you're after a sizzling Marshall type cut, the RV50 probably isn t the amp for you.
You could try to source a now discontinued R30, which cuts effortlessly and is firmly vintage voiced, or the new R32, with its twin 10" speaker, should be great too.
It really depends on what you play and need your amp for
I owned an Rv50 mk II for 6 months one of my main criticisms was that it didn't cut through a band mix like the other Orange amps I had used, due to the very compressed nature of the dirty channel. It also hated overdrive pedals... Such as when used on the clean channel... The mkiii may be totally different!
I say that Thunderverb excells in every genre that has *metal* in its name. Lots of low growling low end, quite edgy distortion, maybe even fizz. Rockerverb is great for everything else - blues, soft-to-hard-rock and more hi-gainy stuff. It's also a bit modern voiced, but yet with kind of vintage twist. Sits nice in a band mix. YMMV.
I only played the RV once, and decided to get the TV instead without playing one. It's definitely a darker amp. Looser, from what I remember of the RV. I've had similar issues with it being muffled, as you put it, but I found a couple of things that help. A Distortion+ in front of it makes it meaner and a bit tighter. An EQ in the effects loop can work wonders too.
I do wish the TV series had a presence control.
Thanks everyone for your insights. I appreciate it ! I think I will roll the dice and order the Rockerverb MKIII. That's what they are selling so its not like I can order a MKII. I kind of like that it has the 25w mode that might make it more friendly practising at home with the attenuator. I find that the attenuator on the TVerb is only really practical when playing at significant volume. Playing at really low volumes just squashes everything sound-wise, which I guess is to be expected with a tube amp.
It's funny how tastes can differ.... I tried both the TV50 and RV50/100 side by side, the RV50 was the amp I bought without 2nd thought.Gorgar wrote: ↑Thu Dec 06, 2018 8:37 pmI only played the RV once, and decided to get the TV instead without playing one. It's definitely a darker amp. Looser, from what I remember of the RV. I've had similar issues with it being muffled, as you put it, but I found a couple of things that help. A Distortion+ in front of it makes it meaner and a bit tighter. An EQ in the effects loop can work wonders too.
I find it amusing how different people can have similar experiences and come to very different conclusions.
Anyway, it doesn't really matter as long as we're all happy in the end.
I declare this thread officially closed LOL
I bought the RV50 and love it !! Definitely a different sound over the TV50 and I am glad I bought it. Thanks to all of you for your insights. This is a very amazing community !!
tony
tony
Nice! Congrats. What did you end up getting? Mk I, II, or III?
Very very cool amp for sure!
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
Got a brand spanking new MK III. Absolutely stunning clean channel and a very nice on board reverb. Not sure yet about the stepped controls but i am sure i will adapt to them.afjungemann wrote: ↑Sun Dec 16, 2018 4:52 amNice! Congrats. What did you end up getting? Mk I, II, or III?
yeah, I am with you on that. Its a bit double edged because for repeatable settings, it is super super easy and nice but I have been "bit" by it a few times where 1 click up is too much but current setting isn't enough. That is where the guitar knobs come into play. If its the gain knob, I just roll off the volume on my guitar a pinch, same with tone, set it a pinch too bright and roll back the tone on the guitar.11tonylevin wrote: ↑Sun Dec 16, 2018 9:05 amGot a brand spanking new MK III. Absolutely stunning clean channel and a very nice on board reverb. Not sure yet about the stepped controls but i am sure i will adapt to them.afjungemann wrote: ↑Sun Dec 16, 2018 4:52 amNice! Congrats. What did you end up getting? Mk I, II, or III?
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
Throw a treble booster in front of your TV50 to cut through the mix, it may give your new MK III a run for its money.11tonylevin wrote: ↑Sun Dec 16, 2018 9:05 amGot a brand spanking new MK III. Absolutely stunning clean channel and a very nice on board reverb. Not sure yet about the stepped controls but i am sure i will adapt to them.afjungemann wrote: ↑Sun Dec 16, 2018 4:52 amNice! Congrats. What did you end up getting? Mk I, II, or III?
I bet you have a good point. But, I sold the TV50pedecamp wrote: ↑Thu Jan 03, 2019 3:43 pmThrow a treble booster in front of your TV50 to cut through the mix, it may give your new MK III a run for its money.11tonylevin wrote: ↑Sun Dec 16, 2018 9:05 amGot a brand spanking new MK III. Absolutely stunning clean channel and a very nice on board reverb. Not sure yet about the stepped controls but i am sure i will adapt to them.afjungemann wrote: ↑Sun Dec 16, 2018 4:52 amNice! Congrats. What did you end up getting? Mk I, II, or III?
I really like the RV50 clean and I think the reverb is much more useable than that on the TV. I kind of also like the 25 w power scaling. I did in fact throw an EQ in the chain and just a subtle treble boost really makes it cut through the mix.
Good deal, enjoy the RV50!11tonylevin wrote: ↑Sat Jan 05, 2019 9:43 pmI bet you have a good point. But, I sold the TV50pedecamp wrote: ↑Thu Jan 03, 2019 3:43 pmThrow a treble booster in front of your TV50 to cut through the mix, it may give your new MK III a run for its money.11tonylevin wrote: ↑Sun Dec 16, 2018 9:05 am
Users browsing this forum: No registered users and 152 guests
