Replacing the master pot was necessary too...Les Paul Lover wrote: ↑Sun Nov 25, 2018 8:36 amThat's a shame... but unfortunately, the heater wire is a necessary improvement!!!!!
AD15 Mods - Questions for the Experts
Re: AD15 Mods - Questions for the Experts
Sooner
AD1512 Serial No. 001
Booh...... what happened to it?Sooner wrote: ↑Sun Nov 25, 2018 1:37 pmReplacing the master pot was necessary too...Les Paul Lover wrote: ↑Sun Nov 25, 2018 8:36 amThat's a shame... but unfortunately, the heater wire is a necessary improvement!!!!!
My own AD15 has started to feedback all by itself with the gain and volume cranked, so I think I'm heading towards a full recap. It isn t valve related for sure.
It's almost 20 years old now, so a recap is on the menu anyway. Not even gonna try to trace, I'll just change all the elctrolytics at once. I have a few projects I need to finish before though.
Master pot was scratchy/intermittent at low volume to the point the amp was unusable with the gain turned up.Les Paul Lover wrote: ↑Sun Nov 25, 2018 4:11 pmBooh...... what happened to it?
I think mine has always squealed by itself with both master and gain all the way up. Haven't checked lately. Kind of afraid to... I've been wondering how much caps really need to be replaced after 20 years. I just bought an 80+ year old radio that's all original and still works. I'll probably replace those caps before I get around to doing my AD15.
Sooner
I've had 15yo caps fail in the power supply of my DVD player a couple of years ago. Swapped it (£0.65) and it's been working fine since.Sooner wrote: ↑Sun Nov 25, 2018 6:05 pmMaster pot was scratchy/intermittent at low volume to the point the amp was unusable with the gain turned up.Les Paul Lover wrote: ↑Sun Nov 25, 2018 4:11 pmBooh...... what happened to it?
The DVD player doesn't really matter, but if a power supply cap failed in my AD15, that could be a transformer gone.......
I still play regularly though.......
Would you mind trying gain and volume maxed and seeing if you get some squeal/oscillation/feedback? You don't even need a guitar plugged in in mine, just does it by itself.
I know the older AD15 I sold didn't do it..... but didn't sound quite as good (still bloody brilliant). Wondering if Orange changed some components value to avoid that feedback, or if mine has something wrong with it.
In any case, it only happens at a setting I'll never use, which is the reason it isn't on my to do list right now.
Just tested with nothing plugged in. Quiet as a mouse even with all the tone knobs maxed out. I may have been thinking about my Fender...Les Paul Lover wrote: ↑Sun Nov 25, 2018 8:58 pm
Sooner
Thank you so much. You're the 2nd forum member to try that out for me, and I really appreciate this. Both of you reported their amps to be dead quiet.Sooner wrote: ↑Sun Nov 25, 2018 10:00 pmJust tested with nothing plugged in. Quiet as a mouse even with all the tone knobs maxed out. I may have been thinking about my Fender...Les Paul Lover wrote: ↑Sun Nov 25, 2018 8:58 pm
Since I know my valves are good, it simplifies the problem solving to a degree.
Recap defo on the to do list. Some way down the line.
Users browsing this forum: No registered users and 250 guests
