OR15 No Sound
OR15 No Sound
Hey everyone, I am new to tube amp ownership and I love the OR15 I purchased used a few months back however after playing the other day I turned it off and when I went to turn it back on the next day I was getting no sound when I plugged the guitar in. I posted on a facebook forum and they suggested I try to replace the fuse next to the power plug (it was brownish). I replaced that fuse and am still not getting any sound out of the amp. When I look at the tubes they appear to be glowing but I feel like they may be dimmer than usual (not sure). I am getting no sound at all. I have checked the speaker cable as well as the guitar cable and both work fine on my other amp which I hate and replaced with this one. Please help!
Re: OR15 No Sound
Have you replaced the EL84 with a new set?
Re: OR15 No Sound
Check the fuse again. If it is blown again, there is a problem with the amp that is making the fuse blow. Most likely a bad tube.
Re: OR15 No Sound
I have the same problem. Although, I have yet to change my fuse. Apparently I need to order one online. It’s a t250mA. My question is that the fuse looks fine, with an intact filament. Can a fuse be bad if it looks good? If the fuse isn’t the problem, what is?
Re: OR15 No Sound
Fuses can look fine yet be blown. Always better to err on the side of just replacing them...tulkas wrote: ↑Sun Jan 13, 2019 12:22 amI have the same problem. Although, I have yet to change my fuse. Apparently I need to order one online. It’s a t250mA. My question is that the fuse looks fine, with an intact filament. Can a fuse be bad if it looks good? If the fuse isn’t the problem, what is?
Re: OR15 No Sound
Yes, I've had a fuse looking fine, but when checked with a multimeter, it was dead.tulkas wrote: ↑Sun Jan 13, 2019 12:22 amI have the same problem. Although, I have yet to change my fuse. Apparently I need to order one online. It’s a t250mA. My question is that the fuse looks fine, with an intact filament. Can a fuse be bad if it looks good? If the fuse isn’t the problem, what is?
Unless you can measure continuity with a multimeter, you cannot be sure.
Users browsing this forum: No registered users and 78 guests
