Orange TH 30 switch on issues
blashyrkh
Post by blashyrkh » Sun Nov 04, 2018 8:02 pm
I have a Orange TH 30 at home. So my amp is switch off at the moment, in stand-by mode and is also on the clean channel. But I switch it on and set it on half or full mode after about 30 seconds, you hear the distorted channel very silently... I switch it to the distorted channel, back to clean and then it works.
What could be wrong?
blashyrkh
Re: Orange TH 30 switch on issues
Post by blashyrkh » Sun Jan 13, 2019 9:11 pm
I’ve already cleaned out my pots, But still the same issue.
Here is a video of my issue: https://youtu.be/CmVjDRRwnQM
robbvant
Post by robbvant » Fri Feb 01, 2019 6:48 am
do you have a foot switch to use on the amp. maybe if you plug one of them in you can put it back in the proper cycle.
steavejoves
Post by steavejoves » Mon Feb 04, 2019 10:08 am
We are using good information and which is really helpful for us. And I use the printer and if I have an error with printer then go to the Epson error code 0xe5 to solve the problem. which provide a good service.
