Orange TH30 won't turn on
This has been an ongoing intermittent problem for a while now. I've already replaced fuses, fuse holder, on / off switch, and power tubes. I just got it back from the amp tech today, he said it was fixed after I waited 5 months. Only to bring it home and find out the problem was not fixed. I contacted orange months ago to find an authorized orange repair tech in the area and they only knew of one in the state (Oklahoma). Which was the guy that did the "work" on my amp. I've got alot of experience building guitar pedals but I'm stumped on this one.
Re: Orange TH30 won't turn on
5 months seems excessive, especially when its not fixed. Have you tried different outlets to rule that out? Voltage needs to be traced in the amp, which is dangerous if you’re not experienced or careful working in it. Check all connections.
Not norman music center.
You should try them then. Ask for Jim and tell him the dude with serial #001 sent you.
Sooner
AD1512 Serial No. 001
