Orange Rockerverb MK1 pre-amp tubes no power
ArnoldNL
Post by ArnoldNL » Sat Oct 20, 2018 12:11 pm
Just got this absolute dreadfully abused Rockerverb MK1 on the testbench... :roll:
The phase inverter tube and the powertubes are lighting up, but none of the other pre-amp tubes are starting to glow. The pots for Mid and Treble on the 2nd channel were busted, so i replaced those.
The tubesocket of the phase inverter was broken, so i replaced it. I've replaced the caps on the phase inverter. I'm seeing some heat-damage on quite a lot of parts, so the amp has been used very well (maybe a bit too well)....
All tubes have been tested and work fine, but for some reason they won't work on this pcb.... All parts have been measured with a LCR-meter and are fine... All wiring looks good...
I'm out of clues... help would be appreciated :)
Re: Orange Rockerverb MK1 pre-amp tubes no power
Post by Jondog » Sat Oct 20, 2018 6:12 pm
Check fuses? replace the heat damaged parts? Reflow solder? Clean everything with de-oxit? Scrap the PCB and hand wire a new amp? :shock:
Post by bclaire » Sat Oct 20, 2018 7:20 pm
After you have eliminated the obvious, you might have to trace the PC board. Doesn't sound like fun. Does the board show any sign of being cracked?
Users browsing this forum: No registered users and 0 guests
