Orange Rocker 30 Problem.
Re: Orange Rocker 30 Problem.
Post by Les Paul Lover » Fri Jul 13, 2018 7:55 pm
Yes, as explained, it's the valve heater circuit you need to check.
I'm hopeful that's the issue for you, as as far as valve amps go, it's a reasonably easy fix.
By the way, jontheid (of great help and assistance when fixing the vakve heater circuit on my 1st AD15) is right- a fuse can look fine and be blown. The 2nd AD15 I had blew its fuse when the valve heater circuit failed. The fuse looked as new - but no continuity there.
Post by Les Paul Lover » Wed Aug 08, 2018 9:01 pm
Did you manage to get it sorted?
Users browsing this forum: Bing [Bot] and 16 guests
