STRINGS! what do you use?
Seeing as how I've been "out of the game" for 5 years I'm shocked to learn that my local shops no longer carry Dean Markley strings. I used to run an 11-50 with a wound third, but I can't find them anywhere and I need to order in "cartons" to get them. I don't like the inconvenience of not being able to drop in and buy, but will probably still do this anyways... in the meantime I loaded up each of my guitars with different variants of 11 gauge strings to see what I'd like.
Telecaster AM PRO: my most used guitar, logged around 20 hours on a set of Ernie Ball 11-48 Paradigm strings. They rusted on me really flippin quick (within 6 hours I noticed it, and I wipe down after every session). snapped the high E at the neck pickup this past weekend.
Put on a set of Dean Markley 11-52 wound 3rd yesterday, too much tension, the extra meat on the bottom strings made it really unruley. Will be ripping these off this weekend.
PRS Cu 24: Been putting some hours on it, about 5 so far. Strung with D'Addario NXYL 11-49. Seeing as how this guitar played stunningly well with the Markleys the slight change in tension did cause a need for some adjustments. It plays pretty good, but the tone seems flatter.
Les Paul Traditional: British Steel 11-48 is the flavor here. Very bright, responsive, and good feeling string. But very limited playing time and I see some rust already. My sweat must be too acidic for these...
Gibson ES-335: Elixr Polyweb 11-49 feel incredibly comfortable, lots of play time on this guitar and they still feel awesome. Still has some top end shimmer and good sustain. This is what I usually put on this guitar tho, and have for years. So it is as I expected...
So far, I like the tone of the EB Paradigms, but not happy with how quickly they deteriorated. I used to change strings monthly with 40 hours a month on them on average. The Paradigms are not cheap either at around $17 CAD a set... Was hoping for a bit more life out of them.
What do you guys use?
-LK
RV50, Vox AC30, Gibson LP Trad '14, Gibson ES-335 '04, PRS Cu24 '10, Fender Tele Pro, Gretsch Powerjet
Re: STRINGS! what do you use?
Elixir Nanoweb user here, 10-46. They are a bit pricey, but last really long and stay "fresh" much longer, too.
However I am short on the money right now, so I'm back to EB Slinky (pink packaging) and they do the job as well.
No strings are better intoned, longer lasting and brilliant sounding that D'Addario 10's for electric guitar, or 12's for acoustic. Been using them for about 29 years. Just my two cents worth.
I've used Gibson Brite Wires 11-50 on 24"75 scale guitars, and fender bullet 10-46 strings for my Vigier, and regular Fender 10-46 for my other 25"5 scale guitar.
Both have been pretty good to me.
I've recently learnt that Daddario is the only company that will recycle strings/drum skins (from any other companies too) so my money will be going to them in the future. I'll have to figure out how I can send them my used strings for recycling too if I can.
Ten guitars, ten tunings so different sets. All D'addario tho.
Orange OR100
White LW100
White LW100
11-52 D'Addario.
which Vigier do you have? they look interesting.Les Paul Lover wrote: ↑Wed Jun 27, 2018 9:06 pmI've used Gibson Brite Wires 11-50 on 24"75 scale guitars, and fender bullet 10-46 strings for my Vigier, and regular Fender 10-46 for my other 25"5 scale guitar.
Looks like most of you guys like D'Addario. I never really found them that awesome... I'll give the NXYL a try on my Tele as they decent on my PRS. never liked the regular XL.
-LK
My Vigier is a Vigier Expert Retro 54. Essentially a classic strat..... beside the fact that it blew away all strats I've had in my hands sinceI tried it. Very well thought out guitar, with a superb neck amongst things. I must say the carbon insert instead of the truss rod is pretty neat..... if you don't change string gauge, you never have to set it up again.Wired wrote: ↑Wed Jun 27, 2018 10:09 pmwhich Vigier do you have? they look interesting.Les Paul Lover wrote: ↑Wed Jun 27, 2018 9:06 pmI've used Gibson Brite Wires 11-50 on 24"75 scale guitars, and fender bullet 10-46 strings for my Vigier, and regular Fender 10-46 for my other 25"5 scale guitar.
Kalium Hybrid 43-150
I feel that these aren't going to be used by many of you guys.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Nowadays I only use Ernie Ball Super Slinkys 9-42, D'Addarios XL 9-42 & Dunlop 9-42 all Nickel wound but thru the nearly 40 years I have experimented with GHS Boomers, Dean Markley Cryo Blue Steels, Gibson Brite Wires, & Fender Bullets. But I always kept going back to the Ernie Balls & D'Addarios, they've been the best all thru the years for me since the beginning.
I've had the best luck with Ernie Ball Slinkys - supers and regulars. Never had a problem unlike the D'Addario's which I tried and had dead G strings right out of the package. Nope.
I like using DR Strings. Pure blues for a more vintage tone and the Tite-Fit for a modern tone. They sound great and last a good long while for me.
Orange Rockerverb 100 MkII
Gibson Custom Shop 2005 Historic 58' Les Paul
I've recently started to use the long life D'addario nxyl strings - expensive but I think worth it, long life, Great tone, better and quicker tuning stability you can certainly see/ feel the higher quality.
I put the NXYL on my Tele last night. don't like them, they just dont feel or sound right... something I've felt about D'Addario for a while. I got a set of EB Cobalts I'm gonna throw on it tonight. Even my PRS doesn't like the D'Addarios, I'm noticing the attack and top end cut is quite a bit less than what I had before with my Blue Steels. Man I hate all the selections LOL
-LK
Watch out for the Cobalts - let me know what you think of them. I found that my guitars didn't sound in tune with them since they allow for an increased magnetic pull compared to nickel. They were literally pulling themselves out of tune.Wired wrote: ↑Fri Jun 29, 2018 1:46 pmI put the NXYL on my Tele last night. don't like them, they just dont feel or sound right... something I've felt about D'Addario for a while. I got a set of EB Cobalts I'm gonna throw on it tonight. Even my PRS doesn't like the D'Addarios, I'm noticing the attack and top end cut is quite a bit less than what I had before with my Blue Steels. Man I hate all the selections LOL
Users browsing this forum: No registered users and 298 guests
