I own a THD Hot Plate, 8 ohms. I am not clear on whether I can use this between a rocker 30 and PPC 212. My understanding from the THD owner's manual is that I can connect the rocker's 8 ohm output to the Hot Plate input and then connect the Hot Plate output to the 16 ohm PPC212 cab
Anyone out there that has used this setup and confirm that it is safe to for the amp?
Tony
Question on THD Hot plate - Impedence
Re: Question on THD Hot plate - Impedence
Hmm... that doesn't sound right to me. I would contact THD about it.
The impedence should be the same on the Hotplate as the amp output and the cab/ speaker.... You'll need the 16 oh version.
Or.... since you need a different hotplate to use with your rocker 30.....
Why not buy a Jet City Jettuanator?
Great attenuator, has 4,8 and 16 ohms taps.
I love mine. I believe you can also use it as load box. It has XLR and DI line out too.
Did try to email THD......no answer. What a badly designed product, making 3 different versions instead of installing a switch. I will look into the Jet City or in meantime use my 8 ohm Blackstar cab with the v30s.
Ironically, on line in the instruction manual, it seems there could be a mismatch as long as the amp and THD unit are matched and the speaker impedance is higher or equal than the THD unit which kind of makes sense since the amp sees the load it has to see. I was hoping someone actually tried that with success.
The THD design is quite old now, and whilst very effective, the Ohms issue has been improved on by other manufacturers like Jet City. Another issue with the hotplate is the attenuation settings, which are fixed. A number of newer attenuator have a simple potentiometer where you can set the attenuation exactly where you want it. It makes fine tuning your overall volume a lot easier.11tonylevin wrote: ↑Sun Jun 24, 2018 11:52 amDid try to email THD......no answer. What a badly designed product, making 3 different versions instead of installing a switch. I will look into the Jet City or in meantime use my 8 ohm Blackstar cab with the v30s.
To my ears the 16 ohm output on orange amps sounds much better than the 8ohm one anyway!
I own an 8 ohm Hotplate too. Yes, that is how I'd run it. As soon as you are attenuating by at least 3dB (and the first step on the Hotplate is -4 the attenuator (not the speaker!) is the majority of the load the amp will 'see'.11tonylevin wrote: ↑Sun Jun 24, 2018 1:54 amI own a THD Hot Plate, 8 ohms. I am not clear on whether I can use this between a rocker 30 and PPC 212. My understanding from the THD owner's manual is that I can connect the rocker's 8 ohm output to the Hot Plate input and then connect the Hot Plate output to the 16 ohm PPC212 cab
Tony
Disagree on the 'badly designed product' comment. It is very solid engineering with solid thinking behind it on the impedance front. Unlike some of the competition who will try to persuade you that they can safely handle any amp output impedance.
Users browsing this forum: Google [Bot] and 449 guests
