Thanks Andy! I couldn't remember for sure.a.hun wrote:The Radial stuff is very good, proper pro level and built to last.No, it is due to the active buffer. Standard passive transformer ones like my Bigshot ABY can be used both ways. (Transformers will transform in both directions!)Thinline_slim wrote:I do have a Twincity and it's been flawless. It has enough capability that I've matched all sorts of different manufacturer amps together. The only downside I have found it that it's only one directional due to the transformer I believe. What I mean by that is you can only run one source in and be split as two outputs. I know there are some passive ABY switchers that can be run both ways i.e. the above scenario as well as take two sources and switch to one output like two guitars into one amp.
Help, ABY switching. Orange Detonator and alternatives.
Re: Help, ABY switching. Orange Detonator and alternatives.
Jake
Guess the easiest way to remember is that an active buffer is basically just like a small signal amplifier. And amps don't work so well backwards - plugging the wrong stuff into their outputs = not so good.Thinline_slim wrote:Thanks Andy! I couldn't remember for sure.a.hun wrote: No, it is due to the active buffer. Standard passive transformer ones like my Bigshot ABY can be used both ways. (Transformers will transform in both directions!)
(Totally OT: Just like transformers ordinary passive loudspeakers can work backwards. In fact you can even use a loudspeaker as a microphone - true! See the sort of useless information my head is stuffed full of...? )
I forgot all about this from a year ago. I just thought I would mention that I have ordered the Orange Detonator after having had the Fulltone on loan for a year, (it wasn't required back until now). Should come tomorrow, Saturday. I will have a chance to compare the two. Nothing wrong with the Fulltone but I have to give it back now so thought I would just order the Orange. Keep it fruity.Rozz wrote: ↑Sun Mar 27, 2016 11:17 am
I have managed to borrow a Fulltone Custom Shop Tru Path ABY ST, picking it up tomorrow, so that was lucky. I will report back, but I have no experience whatsoever of using 2 amps at once, so it will be really interesting for me. I was interested in your post I think Andy, where you like the Vox with orange. I have a little red Vox AC4C1, which I really like cranked, it gets quite loud especially through a PPC112, so I am going to try that. I'm looking forward to it.
Cheers
Rozz
Phil
Gibson Les Paul Traditional, Classic and Tribute. Fender American Standard Strat, Fender MIM Tele, Taylor GS Mini
Orange TH30c with G12H30 Anniversary speaker, 2xOrange PPC112 cabs
Roland Blues Cube Artist. CR120H. Dual Terror
I have the twin city ABY. quiet, phase switch, ground lift. all I need.
Users browsing this forum: Google [Bot] and 150 guests
