NAD: Beaten up AD200B - Updated with Pics
Re: Should I buy a busted AD200B? Update BOUGHT IT
Post by Les Paul Lover » Mon May 01, 2017 8:01 am
Fantastic!!!!!
Sounds like a great great score!!!!
Let us know once it's serviced, if anymore work needed to be done.
At least you've got the right cabs to go with it already!!!
a.hun
Post by a.hun » Wed May 03, 2017 8:04 am
Thats great, well pleased for you. TWO proper Orange bass amps in a few days? I've never even owned one... :lol:
aNDyH. :wink:
ironlung40
Post by ironlung40 » Fri May 05, 2017 1:32 am
a.hun wrote:Thats great, well pleased for you. TWO proper Orange bass amps in a few days? I've never even owned one... :lol:
That is really ironic too! :lol:
to the OP great score! I would have bought it too!
Sincerely,
Ironlung40
OR120 Pix/text
Tiny Terror HW
Rocker 30 combo
Rockververb 100 MKII
Thunderverb 200
Gibson SG 61 RI
OU818
Post by OU818 » Sat May 06, 2017 3:26 am
Dropped it off at my tech for a once over and an expensive retube.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
Re: NAD: Beaten up AD200B - Updated with Pics
Post by Jondog » Sat May 06, 2017 11:45 am
I think it looks awesome!
Post by bclaire » Sat May 06, 2017 7:59 pm
That looks a lot better than I thought it was going to....!
Post by Les Paul Lover » Sun May 07, 2017 9:01 am
It looks great!!!! Did you get all the valves replaced?
How much was the revalve? Still a great after that, right?
Which do you prefer now? OB300 or AD200?
OU818
Post by OU818 » Sun May 07, 2017 10:53 am
Les Paul Lover wrote:It looks great!!!! Did you get all the valves replaced?
Tech has a backlog so probably won't be able to pick it up for another week or so. JJ 6550s are like $40-$50 each so expecting a hefty retube cost. Still, should work out to be a bargain.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
fiveightandten
Post by fiveightandten » Sun May 07, 2017 6:00 pm
Awesome...I'm glad this looks like it's going to work out. The amp doesn't look too bad. I'd "trim" the loose tolex that's hanging off, or glue it back down, and put a proper large gain knob on the amp. It'll be good to go after some new tubes. Enjoy!
To glue tolex down, use a dab of glue and cover the area over with some painters tape while the glue cures. Press down, and don't lift the tape up for at least a few hours. Make sure the glue doesn't spill out past the sides of the tear.
You can use some rubber cement, or just plain old Elmer's glue. I like Elmer's, as it's water based and cleans up easily with a damp cloth if you have excess the squeezes out of the edges.
Post by Les Paul Lover » Sun May 07, 2017 9:14 pm
fiveightandten wrote:Awesome...I'm glad this looks like it's going to work out. The amp doesn't look too bad. I'd "trim" the loose tolex that's hanging off, or glue it back down, and put a proper large gain knob on the amp. It'll be good to go after some new tubes. Enjoy!
Ah ah!!! Whenever I've had to reglue tolex, I've always used superglue..... yes, I'm a hack.
But it's worked fine....... :oops:
OU818
Post by OU818 » Tue May 16, 2017 3:20 am
Well as an update, things have started not looking so good.
My tech spoke with me yesterday and advised that there is a nasty hum and clipping when it gets turned up. He got the schematic and has noticed that various components have been altered by the stage tech of the festival, maybe in order to try and 'supe' it up a bit or get it working with pile of poop tubes..?
No idea.
He is going to replace the parts and investigate the hum. He is 90% sure it isn't a bad transformer however he was originally 99% sure so the odds are dropping.
Hoping to hear back in the next few days. If the cost to re-birth it creeps up I may just cut my losses and flip it to someone who wants to deal with it or repair it themselves.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Post by Les Paul Lover » Tue May 16, 2017 10:11 am
I couldn't believe the cost of your revalve, and googled 6550 and kt88.... ouch!!! They run at around £30 each here!!!!
Hopefully your tech will be able to fix it soon for a reasonable cost.
Components swap are fairly straightforward, and only the big electrolytic caps cost more than a few pennies each.
As a tech, he should be able to replace all components pretty fast. How much does he charge for Labour?
OU818
Post by OU818 » Tue May 16, 2017 11:44 am
I've never actually asked his labour costs. He has built 3 amps for me and worked on all my guitars, basses and other amps. I'm pretty sure he does a good rate for me as often he has charged me 'parts only'.
This time I'm bracing myself for a few hundred at least.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
OU818
Post by OU818 » Thu May 25, 2017 10:47 am
Spoke with the tech today...
It's Alive!
Picking it up on Saturday. Can't wait to give it a sound thrashing 😜
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Post by Jondog » Thu May 25, 2017 12:28 pm
Awesome! What all had to be done?
Users browsing this forum: No registered users and 138 guests
