LETS SEE SOME PEDALBOARDS!!!
Re: LETS SEE SOME PEDALBOARDS!!!
If it's TOO loud...you're TOO old!!!
OR15, TH30, PPC212 OB (x2) CR35LDX
Gibson Les Paul Std (2008 & 2013), Fender Telecaster (Highway One & MIM), Epiphone Sheraton
EHX, Boss, MXR and Mooer Effects
Made a slight change in layout and the VooDoolab PP2+ is replaced by a Cioks DC10. The PP2+ simply wasn't up to deliver the current my effects demand...
Squier 15 (1988)
Mesa/Boogie F50 (2005)
Orange CR60C (2014)
Orange CR60C (2014)
Foef; that is an impressive collection of stomps you've got there! I wish I had known a little more about pedals before I started to form my board...
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
Thanks man! I'll elaborate on the signal chain a bit.Bensnake wrote:Foef; that is an impressive collection of stomps you've got there! I wish I had known a little more about pedals before I started to form my board...
It comes in at the wah which is a Dunlop Jimi Hebdrix JH1B that has a true bypass switch and a blue LED built in.
From there it goes to the Pitchblack, the '69 (germanium) Fuzz that is not really high gain... But can get very doomy in conjunction with the OCD!
Then comes the Pitch Black. Would have liked to have that in front of the fuzz, but it's buffered and the fuzz don't like that... And the tones are nasty in a nice way as it turns out... So hey...
Then it goes into the preloop of the Mobius where effects like phasing, vibe and autowah are programmed. After that it hits the Yellow Comp, The TS9 and the OCD.
From there it goes into the amp input and from the effects send of the amp it feeds into the EP Booster which not only increases the volume but really fattens up the tone which is great for leads çause you wanna have them single notes come out really big, no?
Then it feeds into the post loop of the Mobius where it meets Chorus, Flange and Leslie sim. Then the Carbon Copy and finally the Flint for reverb and tremolo. And that feeds into the effects return. Love the tones i get.
Amps are either a Mesa Boogie F50 or my Orange CR60C. But the board can also be used in front of a clean amp and instead of running it into a preamp i can use a distortionpedal of some type...
Squier 15 (1988)
Orange CR60C (2014)
Orange CR60C (2014)
Hi guys! Look at my new homemade pedalboard!
Amps:
Orange Dual Terror w 2x12 Celestion V30 loaded cab
Marshall JCM800 2210 Head w Marshall 4x10 80's vintage cab
Guitars:
Fender Strat American Special
Fender Telecaster American Special
Fender Strato Mex '94 HSS JB
Guitars:
Been changing the layout a bit. Preparing for the arrival of the Boss DD-500 digital delay.
And the Ibanez TS9 has been replaced by the Maxon OD808. No regrets there.
Squier 15 (1988)
Orange CR60C (2014)
Orange CR60C (2014)
Something tells me that pedalboard won't work. Probably because nothing is connected. Hard to tell what order they are in like that...whybother182 wrote:i need help with the order of these pedals.... did i get them right??
I'd try Tuner > Blue Box > EP Booster > Phaser > Delay > Reverb > Looper > Noise Suppressorwhybother182 wrote:i need help with the order of these pedals.... did i get them right??
No idea about the Superego! I think that depends on what you want to capture/freeze.
TH 30
I've got several and at least one of them usually winds up getting rebuilt every month or so but here's the latest incarnation of the modular setup w/ the drive board I put together for the Oranges and the Marshalls:
Drive board (right):
Fulltone FB-3 > bottom bypass loop (Diamond Marquis > ARC Effects Soothsayer > Zvex Channel 2) > top bypass loop (OR15 in > OR15 loop send > JHS Prestige) > TC Electronic Polytune Noir
Mod/Time board (left):
MXR M108 > Empress Buffer + > left bypass loop (Zvex Sonar > Zvex Instant Lofi Junky > VFE Tractor Beam) > right bypass loop (EQD Disaster Transport Sr. > EQD Ghost Echo) > TC Electronics Ditto > Empress Buffer + > ABY1 in (A > Fender Micro ABY > Amp 1, B > Amp 2)
A filter-tastic shot of the full setup for today:
OR15 as a preamp for the OR50 and 1974x or Remedy is absolutely amazeballs for jangly crunch w/ punch that cleans up really well w/ the volume knob, I'm loving the cleans, and Marquis+Soothsayer+Channel 2 provides enormous building demolishing good times
The drive board seems just about perfect for these amps. The mod/time board has me covered w/ more spacey/funky toys than I could need and will probably see a fair amount of shuffling over time.
Orange Gear
Amps - OR50, Micro Terror, OB1-500
Cabs - PPC212 (G12H 55Hz & G12 Gold), 2 PPC108, OBC115
Pedals - Two Stroke
Pedals - Two Stroke
My Current set up:
Currently using this between the Orange Dual Terror and the AD140.
My current setup:
/J
/J
Orange RV50 MK I Head
Orange PPC412
Orange PPC112 x2
Orange Micro Terror
Ibanez TSA15H
2x Gibson SG Standard
Peter Naglitsch Custom
Fender Tele ´72 Roadworn
Fender Tele FSR Custom
Squier Tele Classic Vibe
Jackson ATX
Jackson TH-2
Hagström Viking
Pedals...
Orange PPC412
Orange PPC112 x2
Orange Micro Terror
Ibanez TSA15H
Jackson ATX
Jackson TH-2
Hagström Viking
Pedals...
Re-kajiggered this PT Jr. setup on Saturday, kind of merging a couple of previous setups:
Guitar/Bass > Keeley C4 > Xotic EP Boost > Bypass Loop [Mooer Ninety Orange > Catalinbread Echorec > Fairfield Circuitry Four Eyes > Fairfield Circuitry Barbershop Millenium > EQD Monarch] > tc electronic PolyTune Noir 2 > Fairfield Circuitry Operator ?! [Fairfield Circuitry Randy's Revenge > Fairfield Circuitry Meet Maude > Subdecay Super Spring Theory] > JHS Buffered Splitter > Amps
Orange Gear
Pedals - Two Stroke
Pedals - Two Stroke
Users browsing this forum: No registered users and 411 guests
