So, being the twiddler I am - I've been messing with pickup changes. When I went to put my SD '59 back in the neck of my Les Paul, I noticed that it sounded like a single coil...I took the joker TOTALLY apart to check the connections and everything seemed to be wired properly, but NO CONTINUITY between certain points.
What in the world could I have done?
Any suggestions / (non-smart arse) advice?
OT: Not getting reading from neck p'up!
Re: OT: Not getting reading from neck p'up!
I suggest posting photos.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
On SD bobbins are:
bobbin 1 Black-White
bobbin 2 Red-Green
Have you tested the bobbins individually? How many ohm do you read ?
The value for each bobbin should be similar. If the ohmmeter display 1, the bobbin is cut.
If both bobbin are ok, connect the white with the red, and mesure between Black and Green.
If all mesurement are ok, try to connect the jack directly on the black (hot) and green (ground).
bobbin 2 Red-Green
Users browsing this forum: No registered users and 356 guests
