polytune 2: yes? no?
Re: polytune 2: yes? no?
the polytune function IS junk for sure
I wish there was some way to turn it off, it is always wrong and keeps getting in the way
I bet the gibson robot tuner is even more worthless but I have not tried it
__________________
__________________
I answered no to the polytune, because I prefer the Hardwire HT6 that have a display in the same layout than the guitar (stupid simple but way more readable tahn the TC one).
If your poll is about POLYPHONIC TUNER, then I would answer YES. In live situation, you can quickly check and tune only the string you need to.
I like em both (TU-2 and Polytune Mini), but prefer the Korg Pitchblack over both.
No buffer in the Pitchblack tho.
Jocke
Rocker 30C
TT
PPC 112
VOX AC30HW2X
'65 Fender DRRI Limited Edition
-79 Gibson Les Paul Deluxe
-82 Ibanez Blazer BL550RB
-86 Squier Strat
-94 Fender P-Bass
-05 Gibson SG '61 RI
-14 Fender Classic Player Baja '60s Tele
Rocker 30C
TT
PPC 112
VOX AC30HW2X
-86 Squier Strat
-94 Fender P-Bass
I replaced my Boss TU-2 with a Peterson Strobe Stomp2 a few years ago. I really like the Peterson but the TU-2 is still a perfectly good tuner. My bass player now uses it.
I could never understand the point of that Polytune's polyphonic "strumming all the strings" tuning function. I would personally never tune that way. Always seemed like a marketing gimmick to me.
Ade
Ade
To check your tuning between 2 songs in an instant. It spot the string you need to retune, and you still retune the string one by one this like with a normal tuner, it's just way faster to see which one need a retune.Ade wrote:..
Ade
I really like it live.
Except it doesn't identify strings out of tune. Mine will say for example that the low E and A are sharp and then when I check them individually, they're perfectly in tune! Waste of time!Hubaxe wrote:To check your tuning between 2 songs in an instant. It spot the string you need to retune, and you still retune the string one by one this like with a normal tuner, it's just way faster to see which one need a retune.Ade wrote:..
Ade
Looks like mine's ok. Got this Hardwire HT6 because I found a cheap one (was also sceptical, and didn't want to spend a lot to try this), and reviews on the web tend to say it's better than the TC.
I used it last week end in a wild gig, and it did what it was supposed to accurately.
I checked the note by note along with the trusty Pitchblack, and the HT6 was ok.
I was about to make this same comment.bclaire wrote:Except it doesn't identify strings out of tune. Mine will say for example that the low E and A are sharp and then when I check them individually, they're perfectly in tune! Waste of time!Hubaxe wrote:To check your tuning between 2 songs in an instant. It spot the string you need to retune, and you still retune the string one by one this like with a normal tuner, it's just way faster to see which one need a retune.Ade wrote:..
Ade
It probably is, but I heard you do get a free guitar with it.everdrone wrote:I bet the gibson robot tuner is even more worthless but I have not tried it
Yeah always seemed like a gimmick to me too.Ade wrote:I replaced my Boss TU-2 with a Peterson Strobe Stomp2 a few years ago. I really like the Peterson but the TU-2 is still a perfectly good tuner. My bass player now uses it.
Ade
I've used various tuners over the years, including an A440Hz tuning fork which never lies and makes a great sound when you put it close to a pickup!
Did get the StroboStomp 2 as well and liked it a lot - both accurate but also very stable in use which I find important too. However... it packed in on me - the display now cuts out after just a couple of seconds. Could probably have it fixed, (may still), but decided just to get a TU-3 as Boss stuff lasts. Very satisfied with it. Used it for several months before even discovering the 'streaming' function which I like a lot and use all the time now. With that it now even reminds me a little of the Peterson too!
I bought a TU2 approx 8 years ago and tune to Eb for a little extra low end. Its done its job brilliantly and not failed on me once...despite having my size 9 squash it on a regular basis. I will agree that it does fail somewhat in bright sunlight but as usual Boss have come up with a winner.
If i did decide to replace it or needed to i'd go straight for the TU3.
If it's TOO loud...you're TOO old!!!
OR15, TH30, PPC212 OB (x2) CR35LDX
Gibson Les Paul Std (2008 & 2013), Fender Telecaster (Highway One & MIM), Epiphone Sheraton
EHX, Boss, MXR and Mooer Effects
Turbo Tuner!
I'm using a Korg Pitchblack because i want it first in my signalchain on the board and it has to be true bypass for the fuzz... Otherwise i'd still be using the Boss TU2 i guess. Both are great tuners anyway. No need for a polyphonic tuner.
Squier 15 (1988)
Mesa/Boogie F50 (2005)
Orange CR60C (2014)
Orange CR60C (2014)
The problem with the TU2 is when it goes into that marquee flashing light mode. And it's always by accident - I'm the only one out of three of my friends that can figure out how to get it out of that mode.... that's the only fault I found with it...Moon wrote:I bought a TU2 approx 8 years ago and tune to Eb for a little extra low end. Its done its job brilliantly and not failed on me once...despite having my size 9 squash it on a regular basis. I will agree that it does fail somewhat in bright sunlight but as usual Boss have come up with a winner.
bclaire wrote:The problem with the TU2 is when it goes into that marquee flashing light mode. And it's always by accident - I'm the only one out of three of my friends that can figure out how to get it out of that mode.... that's the only fault I found with it...Moon wrote:I bought a TU2 approx 8 years ago and tune to Eb for a little extra low end. Its done its job brilliantly and not failed on me once...despite having my size 9 squash it on a regular basis. I will agree that it does fail somewhat in bright sunlight but as usual Boss have come up with a winner.
Nice to know I'm not the only afflicted with mates who can't work their gear!
I've played several years with a guy that was not able to change his guitar strings, and when he plugged a cable it was always in the wrong place..bclaire wrote: Nice to know I'm not the only afflicted with mates who can't work their gear!
Users browsing this forum: No registered users and 248 guests
