Orange Amps Tube Layout Guide
Ammar
Post by Ammar » Mon Oct 07, 2013 11:10 am
evansexcellent wrote:RK50MKII tube layout for combo
FYI....if you have the Head you need to "flip" the rows of 12ax/at7 tubes left to right.
Based on the above can I assume this is the layout for the RV100H Mk I?
Bottom row left-to-right
12Ax7 Clean ----- 12Ax7 Dirty ----- 12Ax7 Dirty ----- 12AT7 Rev ret
Middle row left to right
12AT7 FX loop ----- 12AT7 Rev Send ----- 12AX7 balanced Phase inverter
Top row
4x EL34
stjerky
Post by stjerky » Thu Jan 09, 2014 1:40 pm
Dual Terror (found from another thread)
But what is V1, V2, V3 etc?
Mystic38
Post by Mystic38 » Wed Apr 16, 2014 12:39 am
The best I can understand is that
V1, V2 = dirty channel
V3 = clean channel
V4 = FX loop
V5 = Phase inverter
this reasonable?..
grahamp wrote:Here is the TH30C in an overhead view if you have the chassis pulled with the tubes pointing up.
-Ian-
2014 G&L Fallout
mesa-refugee
Post by mesa-refugee » Fri Mar 06, 2015 11:04 pm
this post confuses me. namely the suggestion of "flipping" the preamp tube rows. why would i want to do that when the diagram matches the physical layout of my RV Mkii head EXACTLY? i could be wrong but his statement seems questionable. can someone verify either way?
Post by Jondog » Wed Mar 18, 2015 11:59 pm
I think the original poster is confused. The control labels are flipped as the combo's chassis sits upside down in comparison to the head . Not the tube positions.
mmcwill
Post by mmcwill » Thu Jan 07, 2016 4:30 am
Does anyone have a diagram of the Rockerverb MKIII 100?
Phlowen
Post by Phlowen » Mon Mar 21, 2016 4:10 pm
mmcwill wrote:Does anyone have a diagram of the Rockerverb MKIII 100?
Yeah, their links are all messed up. Here's the correct link: https://ln-media.orangeamps.com/wp-cont ... -MKIII.pdf
mmcwill
Post by mmcwill » Tue Jan 17, 2017 3:56 am
Unfortunately, the MKIII layout pdf link is no longer active. :(
MojoBlaster
AD50 tube layout question
Post by MojoBlaster » Tue Apr 04, 2017 7:35 pm
Looking at the back of the amp is it V1, V2, etc. from left to right?
MojoBlaster
Post by MojoBlaster » Wed Apr 05, 2017 3:55 pm
After a little bit of due diligence, I have discovered that in the AD50 CS the tube nearest the power tubes is in fact the phase inverter.
Cpounder
Post by Cpounder » Thu May 04, 2017 3:38 pm
Doctor Volume wrote:This is what Len Knitter from orange e-mailed me regarding the TH100 tube layout. Hope this helps a little
Is there anything special about the tube that goes in the phase inverter or is the tube socket just different.
fetchingEllie
Post by fetchingEllie » Sun May 13, 2018 2:50 pm
Is there a layout for the Rocker 15 yet? Based on the physical layout it seems it may be the same as an OR15, but an official layout would be nice.
Cav
Post by Cav » Wed Jan 23, 2019 8:52 am
Hi guys,
Anyone knows where I can find the tube layout for a Dual Dark 50?
Thanks!
Current gear: Dual Dark 50, OR50, Brent Hinds Terror, Dark Terror
Past Gear: RV50 mk2, RV50 mk3, 2x OR15, OR80 2x12, OR120M reissue, TV200, OR50, Terror Bass 500, AD200 mk3, 4-Stroke 500, OB1-300, 2x PPC112, 2x PPC212ob, 2x obc115, PPC412
plushsafehethink
Post by plushsafehethink » Fri Nov 01, 2019 4:03 pm
Does anyone have the tube layout guide for the Tremlord. I'd like to try out some of my NOS tube collection, specifically in V1
Thanks in advance
Post by bclaire » Fri Nov 01, 2019 4:25 pm
Thanks in advance
I think it's too early to have a tube layout for one of these unless someone with one (nod nod wink wink) makes one up....
Users browsing this forum: Google [Bot] and 237 guests
