Rocker 30 circuit
Re: Rocker 30 circuit
Thank you very much!
Treble is still 25k in your schem, 250k is correct.
From which output tap comes the FB?
Finally, the power supply is missing.
Wow, that's a long story. First sorry for my English, I am german. Yes, I comfortable with relays. I do service for my tube amps since a couple of years. I am 47 years old and play for about 35 years. I own some Marshalls, Soldano, Cornford, Fender... and homebrews. Next week a RockerVerb 50 will find its way to my home.
I know the tradegy with schematics. I traced all my amps where the schems could not be found. But this way it's easy when something must be modded or serviced. A good service tech is my friend and he is in business for more than 30 years. Also my father studied tube technology when he was young, so help is always around.
Unfortunately, I don't know anything about your amp and as you told there are no schems around only some spare gutshoots. It would help, if you make some pics and have a look at the relay labels.
Cheers,
Kell
Cheers,
Kell
Cheers! Your english is pretty good I'd say. It uses two DPDT relays. If I get it sorted out, I'm considering doing a handwired version of my Rocker if I get everything nsorted out. Just pull the board out and reuse th chasis and transformers, maybe add some customized features to it in the process like some circuits out of the classic Orange amps they don't use anymore. I think it uses two DPDT relays just for the location of the master volumes on each channel (each side of the board). I'm thinking I could get away with one DPDT relay if I built one.
Hey, put me down for one! Or orange if you're listening, cancel your plans for your new Kirk hammer signature bad monkey amp/pc/tube tester/Katy perry photo album and make this instead!Jondog wrote:Cheers! Your english is pretty good I'd say. It uses two DPDT relays. If I get it sorted out, I'm considering doing a handwired version of my Rocker if I get everything nsorted out. Just pull the board out and reuse th chasis and transformers, maybe add some customized features to it in the process like some circuits out of the classic Orange amps they don't use anymore. I think it uses two DPDT relays just for the location of the master volumes on each channel (each side of the board). I'm thinking I could get away with one DPDT relay if I built one.
Jason
too many pedals
Sure! I want to do it, just for fun. I can always pop the PCB back in if I don't like it.jason41224 wrote:Hey, put me down for one! Or orange if you're listening, cancel your plans for your new Kirk hammer signature bad monkey amp/pc/tube tester/Katy perry photo album and make this instead!Jondog wrote:Cheers! Your english is pretty good I'd say. It uses two DPDT relays. If I get it sorted out, I'm considering doing a handwired version of my Rocker if I get everything nsorted out. Just pull the board out and reuse th chasis and transformers, maybe add some customized features to it in the process like some circuits out of the classic Orange amps they don't use anymore. I think it uses two DPDT relays just for the location of the master volumes on each channel (each side of the board). I'm thinking I could get away with one DPDT relay if I built one.
Hi Jondog,
sometimes it requires more relays than expected to avoid crosstalk between different channels. I exclusively use relays with one switching function. It's also a good idea to use metal housed items to minimize hum. In handwired amps it is sometimes necessary to shield the signal wires, depending on how much gain you use. Grounding the right end can be found by test.
When I'll get my RV, the first step is to capture the schem, as I only found the MK version but not the MKII. It's also my idea to build a handwired version with some tweaks. I really dislike print tube sockets and had problems with it in the past.
I tried to attach a pic of my latest rebuild but it failed – probably I need some more posts. It's a one channel heavy dirty Rock'n'Roller amp with 4 gain stages but no CF, FX loop not jet installed. This one is inspired by Splawn QR and the RV50 MKI. I did it to test and tweak the lead sound, I'm looking for. Finally, the loop will be tube driven and this requires a chassis with more space inside, as this 1987X is too limited in any way.
Cheers,
Kell
Yeah, that's the way how to do itJondog wrote:...I'm considering doing a handwired version of my Rocker if I get everything nsorted out...
Cheers,
Kell
Awesome stuff! One mod I did to my Rocker was a tube driven effects loop. I was able to fit it in nicely, but it's a tight fit. I made sure to use shielded wire for the signal lines. I added a bypass switch for it, and its a really good loop that is very transparent in the signal. The other mod I've done you might of seen in my earlier photo of the board where I've replaced the stock caps with SOZO caps. They really sound good and do a great job of smoothing the tone out. I did a recording of before and after and you really can hear an audible difference.kell wrote:Hi Jondog,
sometimes it requires more relays than expected to avoid crosstalk between different channels. I exclusively use relays with one switching function. It's also a good idea to use metal housed items to minimize hum. In handwired amps it is sometimes necessary to shield the signal wires, depending on how much gain you use. Grounding the right end can be found by test.Yeah, that's the way how to do itJondog wrote:...I'm considering doing a handwired version of my Rocker if I get everything nsorted out...
Cheers,
Kell
Hi Jondog,
how can I attach a file. It does not work with "upload attachment". Do I have to load it to a file server?
Aha, the sozos are not stock... Good idea!
If you want to post a pic you have to upload to photobucket or similar and post as an img
Jondog here are the promised gutshots of the latest. All mounted on a turret board:
The upload seems to work...
Cheers
Cheers
This one has a Bass/Mid/Treble, Vol and MV, Pres. and Depth, a 3-step gain switch and one on the back to choose 8Ω or 16Ω tap for the NFB. It's smoking...
Thanks, for your further art work, nice job, too!
Looking at your schems, it should sound fat and chrunchy with a lot of compression. How does it clean up when you roll back the guitar Vol?
Cheers
Cheers
Cleans up excellent. I've been through alot of amps and this one is the one that stuck. This amp has it's lovers here and haters. They discontinued this model a couple years ago. Alot of people give the Natural Channel alot of flak because it's only 1 gain stage and has no EQ. But it's my favourite channel to use. It's all power amp break up when cranked. Very touch sensitive too. At home I run the preamp into the power amp of a 12AU7 2watt amp I have.kell wrote:This one has a Bass/Mid/Treble, Vol and MV, Pres. and Depth, a 3-step gain switch and one on the back to choose 8Ω or 16Ω tap for the NFB. It's smoking...
Cheers
Don't want to trouble you, but if you got a minute, does this relay path look like it would work? Feels like I'm missing something. Just noticed to the top right pin on relay 2 should be connected to the PI path above the two resistors 45.46, from what I see on the traces anyways.
I'm not seeing why these need to be DPDT relays either.
Hi,
I think there is more than one mistake.
Have a look at this schem.
http://www.orangefieldguide.com/OFG_SCH ... sheet1.jpg" onclick="window.open(this.href);return false;
... wouldn't be surprised if yours is similar to this – of course pure guesswork.
I also noticed, there is no grid leak resistor before R28 to ground (dirty channel). Did you forget it, or do both channels share the same? (Clean channel has R24/1M e.g.)
Cheers
Cheers
Users browsing this forum: No registered users and 215 guests
