Suggest an overdrive pedal for my TH30!
So, i've decided i need a new pedal to use on the clean channel of my th30 to give me a versatile overdrive sound whilst using the gain channel on the amp for my heavier distortion stuff. I guess a nice transparent style thing is what i'm looking for.
So far i've considered the following:
- Providence sov-2
- Fulltone Fulldrive 2
-Wampler tweed '57
-Wampler Ectasy
-Suhr Shiba Drive
Can anyone suggest any more to check out? Or any that work particularly well with Orange's?
~ it would be nice to have a boost function built in aswell; at the moment im using a nasty old digitech scremin' blues as a boost.
- Providence sov-2
-Wampler tweed '57
-Wampler Ectasy
-Suhr Shiba Drive
Re: Suggest an overdrive pedal for my TH30!
Lovepedal Eternity Kanji works great however you just can't go past a Shiva Drive.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
trade up to a TV50.
Dark Lord of the Schwartz
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2016 Gibson LP Standard
2012 Gibson LP Classic Custom
2017 Gibson Firebird Studio T
2018 Taylor 616CE
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
Not sure how much it translates, but I like a Timmy and a Lumpy's Brilliant Boost into the natural channel on my R.30, then use the dirty channel for higher gain stuff.
Both of these are open in the mids while adding upper end grit and/or boost. My stomps that have more mids don't seem to get along with my R.30 so well for low-mid gain. I only use single coils, so YMMV.
guitar > boost/fuzz > trem > echo > amp
better judged by 12 than lowered by 6
I would probs go for an AD30 if i had the moneyDark Helmet wrote:trade up to a TV50.
not NEAR as much gain as the TH30 or TV50...
but yeah... I LOVE that amp.
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
yeh i know, but i'm playing indie-rock stuff at the moment so usually find the upper-half of my Th30's gain knob gets a bit dusty aha.Dark Helmet wrote:not NEAR as much gain as the TH30 or TV50...
if you're doing indie rock and don't need a loop... just swap for an AD30 anyway...
MANY of us have less in our AD30 combo's than you could get for your TH30...
AD30 heads are a little scarcer it seems... but either way...get the AD30!
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
for serious though, check out a JHS Double Barrel. it's got one of the best sounding TS circuits i've ever heard, and is super versatile. plus it has a great jangly sounding overdrive/boost that can be routed before or after the TS side via a toggle switch. very versatile pedal.
Jason
too many pedals
I have considered it man, honestly. But I do play a LOT of stuff and whilst my main band is indie-rock my other projects range from event-covers all the way through to alt-metal. So i do end up appreciating the versatility of the Th30. and it's something i looked at when buying it.Dark Helmet wrote:if you're doing indie rock and don't need a loop... just swap for an AD30 anyway...
I know an AD30 would be more suited to what i'm doing at the moment but i don't want to be in a position in the future where i need the th30 that i traded
The Zvex SHO (boost, not OD) works wonderfully with my TH30...
The Timmy or Danelectro Transparent OD v1 works also very well with it.
Blackstar HT series - I've got a Dual, which is the same as the HT Drive and HT Dist in one pedal. HT Dist is pretty filthy (but does turn down), HT Dual is more of an AC/DC style crunch...
Kerry
Bad Monkey????
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
Check out the Zvex box of rock. It's an OD plus a clean boost all in one. Half of it is a SHO which works really well with my rocker 30 for boosting it. The other half is the OD part. It has 2 switches so it's basically 2 pedals in one! Nice value!
Don't start!!Dark Helmet wrote:Bad Monkey????
Users browsing this forum: No registered users and 403 guests
