What tubes are you using
HI guys just wadering what tubes you guys are using with your orange thunderverb 50 amps thanks
Orange Thunderverb 50
Orange Rockerverb 50 MK1
Gibson Les Paul Standard
Re: What tubes are you using
not a thunderverb 50 but it uses pretty much the same tubes
I use 2 ruby el34's and one ruby ecc83 in the power section and 3 ruby ecc83's in the preamp section... they sound great and they are really smooth and tight...
hope this helps
hope this helps
Wolfy'
don't believe a word this guy says. unless you really want to put ECC83s in the power section...
Jason
too many pedals
The PI tube is considered part of the power section so an ECC83 is fine in there.jason41224 wrote:don't believe a word this guy says. unless you really want to put ECC83s in the power section...
I have a Rockerverb and use JJ and winged-C EL 34's with good results. I'm using Tung Sol 12AX7's in the preamp and PI and JAN Philips 12AT7 in the reverb and FX loop positions. I tried JJ and Mullard reissues in the preamp sections but the Tung Sols just do it for me.
The tubes that came with the amp..
Fender Stratocaster || Les Paul || Garrison Acoustic
Orange Dual Terror
amesav wrote:HI guys just wadering what tubes you guys are using with your orange thunderverb 50 amps thanks
Ruby EL34B-STRs. outstanding EL34s.
the pres are JJ/ehx/nos raytheon
Thunderverb 50,
Yep Tung Sol Pre Amp tubes for me also - really liven the Amp up
you know surprisingly enough, the chinese stock orange glass that it shipped with are my second favorite behind the rubys! thats against JJ, svetlana, =C=, EHX, and new issue mullards.
Thunderverb 50,
Some of the latest Chinese tubes are the best quality I have seen for ages in a modern tube. Groove Tubes are selling them and rave about them too.
Users browsing this forum: No registered users and 362 guests
