Dark Terror. Convert from 110 to 220 volts. How?!
Hi.
I want to buy Dark Terror on eBay, but in my contry voltage is 220. How to convert 110 volts to 220?
I find how make Tiny Terror to 220 volts.
http://s51.radikal.ru/i132/0912/02/47e01e42cb99.jpg" onclick="window.open(this.href);return false;
http://s08.radikal.ru/i181/0912/9d/9c193b9e5f6e.jpg" onclick="window.open(this.href);return false;
If I do the same thing with Dark Terror, then will it work with 220 volts?
Waiting my Orange Dark Terror
Re: Dark Terror. Convert from 110 to 220 volts. How?!
Yikes. I wouldn't let two pictures on the internet convince me to try this. If I were you, I'd get a UK one that IS 220V or have an amp tech do this for you....
The change is very simple but if you get it wrong you could have no amp left. A tech would do it in about 10 mins so it would be cheap to get done professionally and if they break it they are liable
We have no techs to repair tube amps Russia... what more can I say.
Buy in England... hm, there are no england amps on eBay, and no shipping in england stores to my country.
About pictures. It works. Guys write on city's forum, and I belive them in 100%, but its for Tiny Terror...
That looks correct to me but you'll also need to put a lower rated fuse in it too...rizeepalevo wrote:Hi.
Sooner
AD1512 Serial No. 001
Thanks.
Dark Terror and Tiny Terror use the same power transformers, right?
Don't know if they're exactly the same but as far as I know all Orange tube amps since the AD15 (late 90's) can be converted between 120 and 240 volts and the color coding for the transformer wiring is the same.rizeepalevo wrote:Thanks.
Sooner
They are the same) I've cheked it.
And Dark Terror has voltage selection =)
Thanks to all!
Thanks to all!
This is very informative!
I am searching for the opposite... Got a Dual Terror that is a 220v and I need to convert it to 127v.
Should I start a new thread or should we keep it here?
This is the label I see on the transformer:
Thanks!
Thanks!
You can convert it from 220 to 110v by removing the black and red wires from the main power input jack inside the chassis and connecting them together. It should look like this when you're done: (You need to double the mains fuse rating too).
Sooner
Thank you! But joining red and black would match the 220 configuration, wouldn't it?
I want to be very sure since it seems that I got only one shot at this...
Sorry. You're correct. Yours will already have the red and black connected together. You nee to separate those and connect the black with the blue, and red with the brown.
Sooner
Thank you for your help. I was able to change it.
Will leave it here for future reference.
This is how it was set to 220v. Black and Red connected.
This is after the switch to 120v. Separated Black and Red and connected Blue and Black and Brown and Red
Interesting. Judging from the use of electrical tape before you made the change, it looks like your amp was originally wired for 110v and had been converted to 220v before you acquired it?
FWIW I would suggest replacing the electrical tape with heat shrink. Over time electrical tape tends to deteriorate.
Sooner
Thanks for the advice on the electrical tape! Will replace that.
I was surprised to find out that the short stubs of the red and black wires cut and had been tapped along the blue and brown wires.
That proves that it had been converted before.
Which explains what happened when I got the amp.
The 120v is marked on the chassis and the seller told me that the amp was in fact 220v.
I asked him about the difference between the label and the actual voltage... he didn't know.
This is in Brazil where most of the states use 120v and a few use 220v. The guy that sold it to me is from a state south of mine where it's 220v.
From that I can conclude at least two things:
Although I tested it successfully, now I need to get the T2A fuse, since I blew the T1A after a few minutes as expected.
Maybe my next project will be replacing a crackling gain pot on the TT channel. It is not too bad now.
- The dealer he bought it from converted it to sell in that state.
- He had it changed and forgot about it... or simply lied about it. Although I don't understand what that would do for him.
Users browsing this forum: No registered users and 209 guests
