Gut shots of vox ac4tv with questions
Hi there following on from the other vox related thread i thought id ask a few simple questions to see if my proposed ideas are ok.
Here are the pics
My questions are,
There are 3 wires going to the attenuater one is earth and then a red and blue. The blue comes from the transformer and the red is from the speaker jack out which is used for disconnecting the internal and powering an external cab. Might seem like a silly question but to bypass the onboard attenuater i simply connect the blue and red together??
I think i have enough room to put an l-pad in the attenuaters place so would a 15watt 8ohm be ok for a 8ohm 4watt amp as i know they need to be overspeced? Not sure on how to connect an lpad yet but will look into. Any issues with where i want to place it?
The other pic is of the open back bod i done
Here are the pics
My questions are,
Tone is everything
Re: Gut shots of vox ac4tv with questions
The L-pad that you get should come with wiring instructions. If not, then find some for it. You'll simply be replacing the Vox attenuator with the L-pad, if that's how you want to handle it. If the L-pad mounts right into the Attenuator location, then no chassi mods are required, which is a plus. I'd make a very easy to understand drawing/diagram of the attenuator with the colors and lead destinations before you remove it. Keep that note inside the amp. That way, if you want to reverse it, say to sell it as stock, it's as simple as reconnecting it as it was.
The wires stay separated as they are now. The L-pad has three terminals. The ground or - terminal as listed on the L-pad instruction sheet will be connected to the green/yellow wire. The positive signal or + terminal will be connected to the blue wire. The center terminal will be connected to the red wire. That's all there is to it. 15w should be OK. I'd probably get a 25w if it were available and it'd fit in the location that you want it to. I always find that overbuilding everything helps things to not only sound better but to last longer. It costs a bit more, but you only buy once and you only cry once. You might find it more readily useful for another application later also.
-Bill
Thanks for that, i thought an lpad went between amp out and the speaker like youd told me you can make a small box and plug inbetween amp and cab as such. so can i use the lpad as the way they have done there circuit in replacement of there attenuater.
would it be better/more benificial to run the L-pad attenuater like they have or just before the speaker?
Hope this makes sense thanks
Tone is everything
I was reading that fast and saw the big opening in the back off the amp. I thought you wrote ipad and wanted to fit it in the opening which looks the shape of one. A slower re-read was better understood. On on a break from work so I'm rushing.
It does, but that's essentially what Vox has done with the attenuator. So if you want to replace the attenuator, just put the L-pad there. It is in between the amp output and the speaker.Mrjones2004x wrote:Thanks for that, i thought an lpad went between amp out and the speaker like youd told me you can make a small box and plug inbetween amp and cab as such. so can i use the lpad as the way they have done there circuit in replacement of there attenuater.
-Bill
We'll have to wait for the OPC for that.Jondog wrote: I was reading that fast and saw the big opening in the back off the amp. I thought you wrote ipad and wanted to fit it in the opening which looks the shape of one. A slower re-read was better understood. On on a break from work so I'm rushing.
-Bill
I thought iPad too haha
Just curious what's wrong with the stock attenuator?
Thunderverb 50,
OOOOOOOH, lots of lovely spade connectors...Mrjones2004x wrote:
Nothing wrong with attenuater, thought lpad would help retain some of the highs when set low. Didn't realise they did there attenuater like that too.
Spade connecters bad?
Tone is everything
Hey, my AC4TV doesn't look like that!?Mrjones2004x wrote:
I don't have the grille in the bottom. A very strange place for it. You would normally see a heat vent like that at the top of the amp and not in the bottom??
David
I modded the back myself as was to boxy sounding. Sounds better with no bass loss that I can here
Tone is everything
Make Satan look like a saint. Okay they never sank the Titanic or downed the Hindenberg. But only because they didn't exist back then.Mrjones2004x wrote:Spade connecters bad?
They are just a really cheapy crappy short cut to soldering - which is the proper way to do it. Unfortunately they are also to be found in Orange amps, to their eternal shame. These things often seem to be used for (critical!) speaker connections too. Never got that. First thing I do if I ever see that is cut them off and solder. But basically anywhere they are used they can loosen off and lose contact. I hate them!
viewtopic.php?f=3&t=42344&p=511266&hilit=spade#p511266" onclick="window.open(this.href);return false;
viewtopic.php?f=3&t=39993&p=482629&hilit=spade#p482629" onclick="window.open(this.href);return false;
(On his one man mission to rid Orange amps of push on connectors! )
That's what I did with the AC4.a.hun wrote:First thing I do if I ever see that is cut them off and solder.Mrjones2004x wrote:Spade connecters bad?
David
Users browsing this forum: No registered users and 392 guests
