Orange Amps Tube Layout Guide
This thread is for tube/ valve layout diagrams and not for discussion.
If anyone else has tube layouts please post in this thread as an attachment.
Rockerverb 50 MKI: this is for the head - combo is reversed left to right
- Attachments
- RV50 Layout.jpg (80.44 KiB) Viewed 93536 times
-Joe
My mother wears army boots.
RV50 mkI
AC30 combo
Hot tamale.
RV50 mkI
AC30 combo
Hot tamale.
Per Request....
Rocker 30 pre-amp tube layout...
- Attachments
- rocker11.jpg (131.23 KiB) Viewed 93561 times
~mark~
...Just an old guy without a clue!
Thunderverb 50
First row starting with the side closest to the input jack:
1- Channel A&B preamp valve
2- Channel B second and third gain stages
3- Channel A second and third gain stages
Second row of preamps starting closest to input jack:
1- fx loop send/ return tube
2- reverb send/return tube
3- phase inverter
Arrow is the bias trim pot
3- phase inverter
- Attachments
- amp.bias.jpeg (111.31 KiB) Viewed 93321 times
THUNDERVERBER FOR LIFE
No Pedals
Former Marshall addict..
No Pedals
AD30/ AD30R:
- Attachments
- ad30VALVELAYOUT.jpg (16.3 KiB) Viewed 93152 times
-Joe
RV50 mkI
AC30 combo
Hot tamale.
RV50 mkI
AC30 combo
Hot tamale.
Someone actually disagrees with the numbering, though not the valve functions of the TC diagram:
I don't know which is right to be honest.
Oh and apologies for the big pic. It isn't mine!!!
(http://www.eurotubes.com/euro-orange.htm" onclick="window.open(this.href);return false;)
Quite a while ago there was a drawing that someone posted on the Orange forum showing the location of the tubes for both channels.
It seemed like every Orange customer that called us had seen this so rather than spend a lot of time explaining it was incorrect, we
went along with it because the tubes shown for the PI tubes were correct but the "V" numbers were incorrect...
So, the time has come to straighten this out permanently!
The picture below should clear the tube locations up for the AD30TC and AD140TC amps.
Same as on irish admirals diagram - the one misterMagoo just posted? Yes I think that will be right enough for the single channel AD30. The TC is pretty unusual in having a separate PI for each channel. Most TC amps still only have one PI which both (/all) channels feed to.Randy Bass wrote:Does that mean that the older single-channel AD30 & AD30R have the same tube layout even though V2 is for reverb?
RK50MKII tube layout for combo
FYI....if you have the Head you need to "flip" the rows of 12ax/at7 tubes left to right.
Guitars: Gibson LP classic, G&L ASAT special, 83 G&L S500, Fender Mex Strat.
Amps: Orange RK50mkII, Orange AD30htc, THD Flexi 50, Fender Twin Reverb (silverface), Sovtek Mig50(to come)
Cabs: Marshall 425a and Avatar 212 w/v30s
I hope this is of good use to others as well.
This is what Len Knitter from orange e-mailed me regarding the TH100 tube layout. Hope this helps a little
Can I raise a practical question at this point? Are we gonna do "Stonehenge" tomorrow?
OR15 Valve/Tube Layout
CR60C+PPC112 Mini Stack
MarkBass Micromark 801
The Provocateurs Bandcamp
Here is the TH30C in an overhead view if you have the chassis pulled with the tubes pointing up.
Dark Terror tube/ valve layout
Cleaned up this thread... added a couple of needed comments to some layouts and deleted fulfilled requests and conversation.
bclaire wrote:Cleaned up this thread... added a couple of needed comments to some layouts and deleted fulfilled requests and conversation.
Can someone please give me an idea, based on the RV50MKII head layout, of which of these are V1, V2, etc....? I'm replacing my preamps with a mixed set of tubes and I need this info. Also, why is it that the posted diagram above that is for the combo says it has to be flipped for the head but, if you look on the Orange website under the RV50MKII head, it has the same diagram?
Users browsing this forum: No registered users and 163 guests
