what the point of a tube screamer?
i know what it does, and i know the use of it i just want to know in what application can it be usefull in when you have pedals such as eq's, boosts, line drivers, distortion boxes.
im running a mxr 10 band eq, a zvex box of rock and a mxr cae line booster, into a dual terror, can someone explain to me where would the tube screamer go in this?
Thunder 30
Dual Terror
Fender hot rod deluxe
roger linn adrenalynn 3
maxon compressor
mxr: evh 90, micro chrous, 10 band eq, line driver, carbon copy, wah
fender black out telecaster, prs zach myers signature, esp dan jacobs signature, schecter hellraiser
Dual Terror
maxon compressor
- Lord of Orange
Re: what the point of a tube screamer?
It would go into your Fender . I don't see why you'd use it with a Box of Rock, or with an Orange at all for that matter.
well, with the setup i have now? is there a point to it?
Thunder 30
Dual Terror
maxon compressor
Dual Terror
maxon compressor
ya, that doesn't make much sense. you've got it's use covered.
--Nick
- Prince of Orange
It's just a different flavour overdrive. Pay your money & take your choice. All depends what style you're playing as to whether it will stay on your board.
Have you tried one? Do you like it? More than what you've got?
Most overdrive are loosely based around Tubescreamers, so it doesn't have to say Tubescreamer on the can to sound like one.
Joe
G(sus) saves
G(sus) saves
hmmm well i have tried some, i just dont know exactly what it can do to my set up, i guess it can be used as a tone alternative
Thunder 30
Dual Terror
maxon compressor
Dual Terror
maxon compressor
- Prince of Orange
Well... no point trying to fit one in for the sake of it.
If you're happy with your setup, leave it alone!
Joe
G(sus) saves
G(sus) saves
The guys that come and see my band cant believe Im not using any drive pedals...its just my Dual Terror
My opinion is they are best used with Fender amps and other Fender based circuits to push an amp on the verge of breakup to add more drive and some midrange. Also I'd suggest Maxon varients of the the pedal as they are stilled made with the correct circuit unless you plan on spending a bundle on a vintage ibanez which I think is a waste of money. Maxon is the original maker of the pedal and made all of the favored original ibanez models for ibanez. At least that's my understanding of things.
well, I use one with my orange amps, marshalls, etc. I use it for a lead boost. It adds mids which makes you cut through a little better, and it adds sustain. I like to play noisy non-shred, grungy solos, and it really gets the sustain and feedback going for this. Works great for that. As for my rhythm tones, It is all Orange, just with a mxr micromp pushing for higher gain as I like a crunchy core tone for a lot of my verses, and a boost for the high gain for most of my chorus work, so I can switch back and forth that way.
It makes tubes scream.
Pretty self explanitory in my opinion...
Les Paul -> Wah -> Amp
Electric Amp 120w MV - Orange 4x12 + Electric 4x12
I love mine with my AD30, just use its as a little boost for solos and big choruses.
Orange AD30HTC thru Orange PPC2x12. Orange Bass Terror Combo.
Gibson ES-333, Gibson SG Bass, Custom Built Jazzmaster, Les Paul Custom, Kalamazoo KG-1A, Gibson J-45.
I'm with ironlung.
I use it for leads to cut through and a tad of extra gain.
Works like a charm on every amp i've had.
Grtz, Bert.
Grtz, Bert.
Squier 15 (1988)
Mesa/Boogie F50 (2005)
Orange CR60C (2014)
Orange CR60C (2014)
Users browsing this forum: Google [Bot] and 114 guests
