This is an article by Robert Keeley that I use as a rule of thumb for pedal order..
http://www.musicianshotline.com/archive ... r/1104.htm
*swallows pride* Pedal order help?
- Prince of Orange
Think the best rule of thumb is do what works best for you! You'll find some pedals don't work well one way round, but do the other. Some stuff to consider...
Modulation:
Put it where you like, but if you have it before overdrive pedals, the effect won't be as strong as if you put it after. Depends what you're trying to do.
Delays:
I usually have them at the end, so then it replicates the signal you've fed into it, rather than having effects applied to the delayed signal and its repeats. Again, your preference.
Gain / clean boosters & overdrives / distortions:
See comments above, plus, have a think about the relative merits of each pedal. Eg. Say you have a clean booster running into an overdrive pedal, that is going to send (when you switch the clean boost on) a hotter signal into the overdrive pedal, causing it to respond differently to if you just had the overdrive on, but no clean boost, see?
Basically, do whatever works best for you, but have a think about the logic of things too...
Modulation:
Delays:
Joe
G(sus) saves
G(sus) saves
+1blackcloud45 wrote:You want the boost at the end of the chain to boost the signal after the other effects.
the more distortion, the earlier in the chain. thats how i do it, gives me more control and no bad surprises when you turn of a distortion box and get an überloud clean signal because youre clean boost is still on before it.
No... I think the Best Rule of Thumb is to understand how certain effects work first, and then experiment. The Keeley article is just for education and understanding how effects work with other effects, and at the end he says to try different combination's to experiment. Trying different things and not knowing what your doing maybe fun at first, but end up in frustration, and selling and buying Lots of pedals for no good reason. IMO.irish_admiral wrote:Think the best rule of thumb is do what works best for you! You'll find some pedals don't work well one way round, but do the other. Some stuff to consider...
Modulation:
Delays:
Vince
- Prince of Orange
I agree.Drdos wrote:No... I think the Best Rule of Thumb is to understand how certain effects work first, and then experiment. The Keeley article is just for education and understanding how effects work with other effects, and at the end he says to try different combination's to experiment. Trying different things and not knowing what your doing maybe fun at first, but end up in frustration, and selling and buying Lots of pedals for no good reason. IMO.irish_admiral wrote:Think the best rule of thumb is do what works best for you! You'll find some pedals don't work well one way round, but do the other. Some stuff to consider...
Modulation:
Delays:
I think you misread me though... nowhere did I say "Experiment!" and hence my "have a think about the logic of things" comment...
Joe
G(sus) saves
G(sus) saves
Sorry Joe didn't mean to misinterpret you, I was just commenting on the whole rule of thumb thing. In no way am I saying that this Keeley opinion is the end all be all on the topic of pedal order/setup, but a good place to start to understand how pedals work or possible may not work properly together. Anyhow I just hate hearing about people buying a ton of gear(100's of pedals), and not taking the time to understand how they work and then selling in the pursuit of the same thing over and over.... Anyway sorry for the rant. Cheers!irish_admiral wrote:I agree.Drdos wrote:No... I think the Best Rule of Thumb is to understand how certain effects work first, and then experiment. The Keeley article is just for education and understanding how effects work with other effects, and at the end he says to try different combination's to experiment. Trying different things and not knowing what your doing maybe fun at first, but end up in frustration, and selling and buying Lots of pedals for no good reason. IMO.irish_admiral wrote:Think the best rule of thumb is do what works best for you! You'll find some pedals don't work well one way round, but do the other. Some stuff to consider...
Modulation:
Delays:
Vince
i am yet to try keeley's advice on placing comp after distortion
LIKE SPACE ROCK? = VAN CLEEF @ BANDCAMP http://vancleef.bandcamp.com/
Mesa Roadster, Egnater Rebel, Orange Terror, Blackheart Giant • Ric 360MG, Schecter C1, Martin OMC15, Moog Phatty/6 Foogers, Korg microXL/Electribe MX • Alesis, Boss, Mackie, Peterson, Radial ( o )==#
http://gamefreaks.net/defrag/personal/music.html ♪♫
Re: *swallows pride* Pedal order help?
Distortion by its very nature is compression, making a sine wave into a square wave. I do see the occasional use of compression on distorted gtrs in a mixdown situation, but not often in a live rig, so I`d probably always run the compressor before the distortion if I was using distortion,although compression is a mostly clean or semi-clean effect for me.
Boost in the loop. Just tried it, whole new TYPE of gain. Good kind.
Thunderverb 50,
Correct. Last but not least, don't forget the output impedance of each pedal/box. Running the volume pedal at the end of the chain ruins everything actually. Altering the position (level) of the volume pedal, changes the input impedance of the amp too. Because the pot inside compromises it. Could genarate interesting sounds thoughceedee1954 wrote:Distortion by its very nature is compression, making a sine wave into a square wave. I do see the occasional use of compression on distorted gtrs in a mixdown situation, but not often in a live rig, so I`d probably always run the compressor before the distortion if I was using distortion,although compression is a mostly clean or semi-clean effect for me.
Cheers,
Daniel
Daniel
I have my volume pedal after my fuzz/dist and before my delay. That way I can realize volumeswells that are carried on by the delay
Users browsing this forum: No registered users and 468 guests
