Fender Twin Craigslist...
Good Q. I know nothing about these amps. Just checking with you guys to see if its a deal. Think it takes pedals well?kittenface wrote:what's so 'Vintage' about it??
Ditto that. It's a later 70's REALLY less desirable master volume Fender Twin (note additional knob to the right slightly apart from the rest). I had one of these and it would be a lot more difficult to convert it to blackface specs. It has a lot more going on with the master volume thingy- it also has a pull distortion that uses the reverb circuit to add horrendous distortion.
$700 is too much IMHO. Especially for an amp that's not going to sound good, and you'd have to spend lots of money to make it sound better...
i wouldnt even go for it. thats just me. its a big chunk of money, and if it were me, id wait till i found the right amp instead of being iffy about it.bclaire wrote:Ditto that. It's a later 70's REALLY less desirable master volume Fender Twin (note additional knob to the right slightly apart from the rest). I had one of these and it would be a lot more difficult to convert it to blackface specs. It has a lot more going on with the master volume thingy- it also has a pull distortion that uses the reverb circuit to add horrendous distortion.
-tim
fender double fat strat through:
TT-->BYOc tri-boost-->avatar 1x12 w/ greenback.
fender deluxe 'verb.
could be an earlier silverface. i've got one with the master volume and it doesn't have the crappy pull-pot distortion. i'd check it out, but i wouldn't drop too much on it.xTRUTHOFMYYOUTHx wrote:i wouldnt even go for it. thats just me. its a big chunk of money, and if it were me, id wait till i found the right amp instead of being iffy about it.bclaire wrote:Ditto that. It's a later 70's REALLY less desirable master volume Fender Twin (note additional knob to the right slightly apart from the rest). I had one of these and it would be a lot more difficult to convert it to blackface specs. It has a lot more going on with the master volume thingy- it also has a pull distortion that uses the reverb circuit to add horrendous distortion.
You sure? I thought EVERY master volume Twin had the pull distortion thingy. Ever try pulling on it?chinese fork tie wrote:could be an earlier silverface. i've got one with the master volume and it doesn't have the crappy pull-pot distortion. i'd check it out, but i wouldn't drop too much on it.xTRUTHOFMYYOUTHx wrote:i wouldnt even go for it. thats just me. its a big chunk of money, and if it were me, id wait till i found the right amp instead of being iffy about it.bclaire wrote:Ditto that. It's a later 70's REALLY less desirable master volume Fender Twin (note additional knob to the right slightly apart from the rest). I had one of these and it would be a lot more difficult to convert it to blackface specs. It has a lot more going on with the master volume thingy- it also has a pull distortion that uses the reverb circuit to add horrendous distortion.
(ha ha ha ha ha! I just read what I wrote and almost pee'd myself when I read it!)
Users browsing this forum: No registered users and 235 guests
