Picture Gallery! (No comments allowed!)
[img][img]http://i133.photobucket.com/albums/q74/ ... icture.jpg[/img][/img]
Orange AD30HTC thru Orange PPC2x12. Orange Bass Terror Combo.
Gibson ES-333, Gibson SG Bass, Custom Built Jazzmaster, Les Paul Custom, Kalamazoo KG-1A, Gibson J-45.
Top View of my Orange Overdrive 120 Combo (Reissue) with 2 Electro Voice 12L (i needed a 16 Ohm cab to use it with my additional Orange PPC212 cab and the old Celestion G12-T75 had 8 ohm in parallel wiring...)
just another point of view...
Orange Overdive 120 Combo (reissue) with a new Orange PPC212...as you will mention the new orange PPC cabs are wider than the combo...
my "small gig" Setup an Orange Overdrive 120 Head (Reissue) with my old Ampeg SS412ES(Celestion G12-M70) an the new Orange stack...with a Orange Overdrive 120 (reissue) and the Orange PPC212
picture of my floorboard...
Input Guitar -> "Snarling Dogs Erogenous Moan" Volume + Tape Reverse -> "Fuzzy Mama" DIY Fuzz Face Clone with gain set to 75% only Volume is adjustable -> "Electro Harmonix Little Big Muff" -> "Snarling Dogs Mold Spore" Wah Wah + Ring Modulator (tunable frequency per pedes) -> DIY A/B Switch with a carlington DPDT Switch where the ground is switched to so no 50/60Hz buzz....
http://www.backtomama.de my band
http://www.myspace.com/backtomama an the Myspace site
New Thorn Artisan #39 in direct sunlight
Wagner (www.crcoils.com) Filmore pickups + LR Baggs piezos
5-way switch: 1-Neck H, 2-Neck H (parallel coils), 3-Neck+Bridge H, 4-N+B (outer coils), 5-Bridge H
Volume, neck volume, tone, then piezo vol/blend knob/switches
Other gear pics in my sig. Here's an oldie but goodie of me RV50 + Divided by 13 2x12:
CIJ TL-52 with the US Vintage pups, and my frankenstrat (amazing 80's neck with a WD sunburst alder body, Kent Armstrong pups and blah blah. There's my bitmo-trio-modded valve junior and my traynor ycv40+v30.
'86 Gibson SG-62
'83 Jap Squire 70s Strat ala Hendrix
Orange AD30R, DD20, Modded Fuzz Face, Jimi wah, Boss PS-3, RP80
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Norrin Radd</i>
<br />Well, this is the latest, doesn't show ALL my gear, but my basic at home playing/recording setup:
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Hi Norrin, just looking at an older thread on the forum which shows your playing/recording setup. Hope you don't mind asking for a bit of info, its just I noticed you had a M-Audio Fast Track & a Line 6 PodXt. Are you using the pods effects when recording through your M-Audio interface? If so what is the sequence of events here. Is it: 1)Interface plugs into computer via USB, 2)Guitar plugs into interface 3)PodXT plugs into Interface also somehow.....I'd just prefer to use external effects than software driven effects when I start recording and I'm new to this. I also wandered if you could go...guitar into PodXT then into interface as you would with an amplifier or does it not work like this for recording? Any help would be greatly appreciated....Thanks, Johnny (21rush12)
Johnny
mmmmmm drop
Guthrie Matthews Method
Users browsing this forum: Google [Bot] and 431 guests
