helpful tip for obc410 owners
steps for the easiest way to disconnect the horns attenuator without worrying about crimped clasps, physically removing the horn, or loose wires.
step 1-- if you're facing the front of the cab, locate the handle at your right hand side.
step 2--unscrew the handle.
step 3-- locate the two fuses soldered together going vertical. they are housed in a metal fuse holder furthest away from you.
step 4- with bare hands (don't use pliers) scoop and pinch the bottom fuse upwards and remove. (this may need a decent amount of force).
this will disconnect the bass from reaching the horn and will not effect the cabs impedance.
just replace the fuses in order to have the tweeter working again!
the end.
the end.
Bass: orange-ad200b, obc4x10, obc1x15/ ampeg b-15/ fender Jazz/ 74' gibson grabber/ peterson stobeostomp/ ehx deluxe memory man/ malekko b:assmaster/ voodoo labs pedal power 2+/ monster bass cables
Guitar: Fender 69' Tele Thinline/ Ampeg B-15
*korey*
*korey*
uhm yea man it should be easy to tell if the horn is off or not, it should take away some of the harsh brittleness on top.. sounds alot better imo when its alone.. with the 15 i prefer it on.
*korey*
*korey*
well i got the fuses pulled out so i guess that means its off. the more i play the more i notice that the harsh sizzle is gone, so i guess it did work.Originally posted by Heartsndspades
sorry about before, i guess it just took a little while for my ears to adjust.
1969 Fender Jazz Bass
Former Pics Only OR120 Owner (hope to own one again soon!)
Cool tip!Originally posted by Heartsndspades
steps for the easiest way to disconnect the horns attenuator without worrying about crimped clasps, physicaly removing the horn, or loose wires.
Question though: Do the cabs really come with a horn attenuator now? That would be a much needed improvement...
http://forum.orangeamps.com/viewtopic.php?t=13961" onclick="window.open(this.href);return false;
I sure don't think it's a problem. When I compare it to my Peavey 210 cab I can hardly hear it. The Peavey has an attenuator and when you open it up, that thing sizzles like crazy. I've never had even close to that kind of high-end action with the Orange.Originally posted by Aranciata
i was thinking of getting this cab to match an AD200B, but i'm being put off my the tales of the horn. Is it that bad? I know everyone has differing opinions.
Oranges are sweet!
no need to apologize mark, i got the tip from will at orange usa.. sorry if i came off like a roger i was gettin ready to leave. i guess the easiest way of telling is putting ur ear up to it lol.. what basses you playing?
*korey*
*korey*
i'm using a 69 fender jazz, Musicman Stingray 5, and Gretsch G6072 Hollowbody.Originally posted by Heartsndspades
I had just put new strings on my Jazz, when i did the horn disconnect so i think initially i was wondering where the sound was. But after playing i noticed that a lot of the String noise and sound like that, that were amplified by the horn, were in fact gone.
So the horn is off and it sounds cool, a little more old school if you will.
Re: helpful tip for obc410 owners
Sorry to drag up an old thread, but I have a question. Do you pull both fuses, or just the bottom one?
Thanks, Lenny.
Thanks, Lenny.
I think one alone will do it...
If it's an American-made OBC410, also double-check that it is really 8 ohms. Mine was wired incorrectly...
So, I pulled the right hand side handle, and all I could see was the crossover on the back panel. I didn't see any fuses at all. Or at least not traditional looking fuses anyway. Is that where ther're located? On the crossover PCB?
Thanks, Lenny.
Thanks, Lenny.
Users browsing this forum: No registered users and 260 guests
