OR120M, help me date this thing.
Mattias666
Post by Mattias666 » Fri Jun 25, 2010 9:00 pm
Hey guys, alot of good reading on this forum.
If you would help me date my amp I'd be greatful.
/Matt
Sooner
Re: OR120M, help me date this thing.
Post by Sooner » Fri Jun 25, 2010 9:12 pm
Looks like 1978: http://web.archive.org/web/200806291318 ... eline.html" onclick="window.open(this.href);return false;
Sooner
AD1512 Serial No. 001
Mattias666
Post by Mattias666 » Fri Jun 25, 2010 9:16 pm
Indeed it does, thanks for that.
a.hun
Post by a.hun » Mon Jul 05, 2010 8:36 am
There may well be a date tag inside attached to the board. My OR120M, ser. no. 015637, is stamped 10th Aug. 1978.
If you do remove the chassis to check for a tag DON'T touch anything on the circuit board!!! There may be very high (lethal!!!) voltages stored in the big capacitors long after powering the amp down. Maybe best just to have your tech check this the next time he has the amp open eg for biasing up new power valves. Indeed pretty much certainly a '78 though.
aNDyH. :wink:
Mattias666
Post by Mattias666 » Thu Jul 08, 2010 1:03 pm
a.hun wrote:There may well be a date tag inside attached to the board. My OR120M, ser. no. 015637, is stamped 10th Aug. 1978.
Interesting, will have a look.
Is the bias fixed on these things or will I have to get it rebiased after replacing tubes?
a.hun
Post by a.hun » Thu Jul 15, 2010 7:02 am
Mattias666 wrote: Is the bias fixed on these things or will I have to get it rebiased after replacing tubes?
Both!
'Fixed' biasing is a slightly misleading term. It doesn't mean that it can't be adjusted, only that once it is adjusted it stays at the set level. So yes you do have to have the bias checked for new power valve sets. Make sure you get good strong valves too or the OR120 will trash them in no time. You'll be good with things like JJ or 'Winged C' brand SED Svetlanas. Most other modern ones won't last long at all though as the amp voltages / currents are unusually high.
The other type of amp biasing - 'cathode' biasing - is only found on some lower powered amps (up to about 30W output power). This type of circuitry gives a range of 'self adjust' shifting the bias current both for different valves and for different levels of signal. So while the range can also be adjusted by a tech it doesn't stay fixed at any one level.
Only power valves need bias checks BTW. Preamp valves can just be replaced with no such worries.
aNDyH. :wink:
Mattias666
Post by Mattias666 » Fri Jul 23, 2010 10:09 pm
Thanks for the info!
