Seen one of these on ebay for sale for £600. Don't know much about Oranges (I always used Marshalls). I currently have a JTM45 loaded with KT66s. I was wandering what the stock valves are like and what is a good replacement?
Also if anyone is good with serial numbers (serial number OR 30C / 204 / 200).
Orange AD30R
Re: Orange AD30R
Hi jodders1976.jodders1976 wrote:Seen one of these on ebay for sale for £600. Don't know much about Oranges (I always used Marshalls). I currently have a JTM45 loaded with KT66s. I was wandering what the stock valves are like and what is a good replacement?
The single channel AD30 reverb was a good amp. Nice, simple, good sounding and with great touch sensitivity. 'Irish Admiral' our top poster here has one and will probably be along shortly to agree. He may even have some little tweaks for you.
Wouldn't worry about the stock valves. Chances are they were Chinese junk and all died long ago. If not than replace them with something like Electro Harmonix (generally brighter sounds) or JJ (fuller less toppy sounds), or a mixture. These are the sort of better quality valves Orange now tend to use themselves. Valve tonal preferences are down to individual taste though. Trying a forum search will get you plenty of different opinions...
Don't know what is going on with that serial number though. They used to be pretty much meaningless, but this info is from a 2004 thread, when Orange tried to bring order to the chaos:
That would indicate to me it is a pretty early AD30R, but I'm only guessing.Admin wrote:(http://forum.orangeamps.com/viewtopic.php?t=1266" onclick="window.open(this.href);return false;)
The last four digits of the AD series serial numbers tell you the month and year it was made. For example 1564-06-03 was built during June 2003 (O6-03).
Jason
Re: Orange AD30R
That appears to be the serial number format used when the amps were manufactured by Trace Elliot. Probably February 2000.jodders1976 wrote: Also if anyone is good with serial numbers (serial number OR 30C / 204 / 200).
Sooner
AD1512 Serial No. 001
Re: Orange AD30R
Were they any good in that era?
Re: Orange AD30R
Oh sure. The basic design of the amp is prett much unchanged apart from adding a near identical preamp channel, and losing the reverb.jodders1976 wrote:Were they any good in that era?
Main performance upgrades since the time are better quality stock valves and upgraded transformers. On the transformers:
http://forum.orangeamps.com/viewtopic.php?t=6826" onclick="window.open(this.href);return false;
There may have been other slight circuit changes I'm not aware of but nothing major AFAIK. Like I say, good amps!
Re: Orange AD30R
Well I got it for £550 in the end. One of the vavles seems to glow up really bright when you first turn it on but then glows the same as the others, suspect it needs new ones. Might try a complete set of JJs. Also the back cover where the amp sits on needs a replacement so off to Orange to see if I can source one of those. Other than that played my Les Paul through it and it seems louder than the JTM45. Can't wait to try this at a gig.
Thanks for the advice
Re: Orange AD30R
You're welcome, and I'm glad to hear you grabbed it - good move!jodders1976 wrote:Well I got it for £550 in the end. One of the vavles seems to glow up really bright when you first turn it on but then glows the same as the others, suspect it needs new ones. Might try a complete set of JJs. Also the back cover where the amp sits on needs a replacement so off to Orange to see if I can source one of those. Other than that played my Les Paul through it and it seems louder than the JTM45. Can't wait to try this at a gig.
Joe (irish_admiral) didn't turn up, but was just talking about an AD30R here:
http://forum.orangeamps.com/viewtopic.php?f=2&t=40393" onclick="window.open(this.href);return false;
If the glow is just the normal central heater element I wouldn't worry about it. The valve glows you should worry about are if you ever see any signs of RED PLATING, ie red glow from the valve plates. See the pic on that linked thread for an example.
Sure grab a new set of EL84s and keep the old ones as spares if they still work okay in comparison. Always handy.
Good luck with the new amp then!
Re: Orange AD30R
Cool. Now when you get a chance you can open it up and check the inspection sticker to get the exact manufacture date.jodders1976 wrote:Well I got it for £550 in the end.
Sooner
Users browsing this forum: No registered users and 107 guests
