<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by aperfectsonnet</i>
<br />Thanks for the welcome and the help...how many hours should i wait to try and see?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Not worth thinking in terms of hours! The very big filter capacitors can potentially store hundreds of volts DC for days to weeks - easily enough to kill. The only way to be safe working in valve amps is to know how to safely discharge them. (Depending on design this happens automatically within a few minutes in some amps, but not usually in very simple old designs.)
If the amp is new to you I would definitely suggest getting a good tech to check it over anyway for safety and reliability. Those same filter caps have a limited working life and if original would be long overdue for replacement. Especially if being powered up for the first time in a couple of years they have been known to explode filling the amp with nasty corrosive gunk. (I know because it happened to my own tech with one of my own old amps!
Also you'd want the biasing of the power valves checked so they are running in the right current range. Just ask them to check for a date tag while they are at it. But as I say the chances are that if there was one it would probably just confirm the year suggested by the timeline.
